had my injen cai installed
Old Apr 19, 2004 | 05:59 PM
lemieux's Avatar
lemieux
Default had my injen cai installed
is it normal that now that my injen cai is installed that my car feels like its going to stall when im in park. doesnts stall but feels like it may. thanx. and also how do i clean my filter and how often
Old Apr 19, 2004 | 06:07 PM
ttsupra94's Avatar
ttsupra94
It shouldn't feel like it is going to stall. Had mine in for about 6k miles and never had that problem. Did you make sure to unplug the battery during install? You are supposed to put in a new filter every 14k miles i think. It says when to change the filter on the instructions
Old Apr 20, 2004 | 07:13 AM
maximumsportZ's Avatar
maximumsportZ
Actually, you can just recharge the K&N Filter its ment to be reused. Just buy a cleaning kit and re-oil it.
Old Apr 20, 2004 | 08:12 AM
Jung918's Avatar
Jung918
what does the butt dyno say?
Old Apr 20, 2004 | 08:51 AM
DriftinZ's Avatar
DriftinZ
Why do you have to disconnect the battery during a CAI install? Im installing mine this week. Thanks
Old Apr 20, 2004 | 12:37 PM
jckolnturn's Avatar
jckolnturn
Default Re: had my injen cai installed
How do you like the Injen intake other than the idle problem? Is it the new one or the old one?
Old Apr 23, 2004 | 02:24 PM
lemieux's Avatar
lemieux
its the new one. it sounds sick. i love it other than the low idle. i wrote to the guy at performance who installed it and he said its normal and will ease up after some time. overall its awesome
Old Apr 23, 2004 | 03:47 PM
mofoz's Avatar
mofoz
can you link to pics of the new one? i have the chrome/black RD one. Mine sounds sick, and sometimes feels likes its gonna stall. I think im gonna reset my ECU as well.
Old Apr 23, 2004 | 04:22 PM
lemieux's Avatar
lemieux
it looks exactly the same. its the inner design thats different. 9.5 hp. better than the other which i beleive was only 5.5
Old Apr 23, 2004 | 04:56 PM
CTZ's Avatar
CTZ
lemieux...I have the same idle problem with the stock intake. However.. i did get a polished plenum installed (which requires seperating the stock intake from the intake manifold) and according to computer tests it is because of a intake gasket leak. I bet you have the same problem.
After idling for a bit my rpms dip down and the car stutters a bit like it wants to stall.
I am having an Injen intake installed next week so hopefully the problem will get resolved.
Hope that helps.
Old Apr 23, 2004 | 04:58 PM
CTZ's Avatar
CTZ
Curious... those have have the Injen intake. How much of a PITA is it to maintain? Having to take off the bumper to do this blows!
Old Apr 23, 2004 | 08:54 PM
03 Z for ME's Avatar
03 Z for ME
For the Millionth time... You DON'T have to EVER take the bumper off....
Old Apr 23, 2004 | 11:00 PM
onii's Avatar
onii
how did u install the lower arm without taking off the bumper? i have it installed as a short ram, and if it's not a big hassle, i want to install the rest.
Old Apr 23, 2004 | 11:24 PM
FairladyZ's Avatar
FairladyZ
You jack up the car and take off the lower panel. Thats it!
Old Apr 24, 2004 | 12:01 AM
onii's Avatar
onii
o yeah? is there a guide somewhere explaining a bit more? i just started this whole working on cars thing, so i need some more guidance.
Old Apr 24, 2004 | 04:21 AM
FairladyZ's Avatar
FairladyZ
Believe me, if you jack the car high enough (thats the key), and take off the bottom paneling you will see how much room you actually have to work.
You will also notice two holes for the mounting of the filter (kinda adjustable), if one hole fits better then the orher use it.
Old May 2, 2004 | 11:37 AM
frank hill's Avatar
frank hill
the problem with injen intakes is that they move the pcv hose to before the airflow meter instead of behind. this causes unmetered air to enter the engine at idle causing lean running conition(lean misfire)swap the factory top tube for the injen and move pcv hose back to factory location then plug port at airflow meter adapter.reset ecu re learn idle air volume and idle will be fixed
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
