nismo exhaust nightmare!!!!!
Old Apr 29, 2004 | 07:35 PM
denic79's Avatar
denic79
Default nismo exhaust nightmare!!!!!
A couple of weeks ago my middle pipe on my nismo exhaust broke. So I had a new one sent to me. I sent the old one back and that costed me $40.00 to send. Installed it myself and it was fine. Then a couple of days later the flex on the "Y" pipe started to rattle on the right side. Now today I heard the exhaust leaking so I brought it to my work and raised it up on the lift thinking maybe a bolt came loose. Not even close the middle pipe broke in the same spot. Brand new pipe still shiny and not even a spec of dust. It has been a total nightmare since I bought this exhaust. I don't know if I should remove the whole exhaust and just send it back to where I bought it or try to put a good weld on the pipe and get a Jic "Y" pipe. I'm really desperate for some opinions.
I thought when you spend $1,000.00 for a exhaust it should last more then a year.
Old Apr 29, 2004 | 09:03 PM
Jsn350Z's Avatar
Jsn350Z
Wow, sorry you are having a bad experiance with this exhaust.
Mine bolted right up, perfect fit, and only took me 25 minutes with a lift. It still perfect with no problems. Also, the welds on it are some of the best I have ever seen.
Old Apr 29, 2004 | 09:08 PM
scubasteve's Avatar
scubasteve
Personally, I would go to your Nissan dealer, as this exhaust should be covered under your warranty, or at least go back to the place you purchased the exhaust from. I had some MINOR problems with mine rattling at first, but now, no problems. I love my exhaust and would not hesitate purchasing it again. Good luck!!
Old Apr 29, 2004 | 09:16 PM
Donald0730's Avatar
Donald0730
I think Nissan does warranty Nismo parts cept for the R-tune stuff. I hope they don't give U BS like "It's your fault, U didn't install it right". Good Luck.
Old Apr 29, 2004 | 09:19 PM
seb676's Avatar
seb676
Default Re: nismo exhaust nightmare!!!!!
Take a look at your motor mounts. Check to see if they're loose or worn. I highly doubt it on a new car, but you never know.
Usually at work, if the same car keeps coming back to the shop with a bad flex pipe, their motor mounts are loose or worn out. They'll keep breaking from the motor moving too much.
Shawn
Old Apr 29, 2004 | 11:04 PM
scz's Avatar
scz
The same thing just happened to me tonight only I have no idea what is leaking. This is the second time I have had an exhaust leak and both were after a redline run. I just put the car up on the BS car jack in my underground garage and I cant find a thing. All my bolts are tight and it seems like all the welds are good. Any suggestions would help.
Old Apr 30, 2004 | 02:48 AM
Sz28r's Avatar
Sz28r
No problems with my Nismo exhaust, although I did jack it up and look at the welds last weekend after reading some of these threads - - but I'm good - - good luck, I hope you get yours resolved.
Old Apr 30, 2004 | 05:19 AM
BrianLG35C's Avatar
BrianLG35C
Did they tell you what was rattling?? Man I wish I could figure out a solution to mine!
Old Apr 30, 2004 | 05:28 AM
DavesZ#3's Avatar
DavesZ#3
The warranty on NISMO parts is only valid when a dealer installs it, not when it's self-installed. If you bought it through a dealer you might get a "defective part" coverage and they would swap it out. You won't get a warranty to coverage installation, rattling, etc.
Old Apr 30, 2004 | 06:12 AM
BrianLG35C's Avatar
BrianLG35C
My problem is my Infiniti dealer is unable to warranty my exhaust because Nismo requires an actual Nissan dealer to do the install to get warranty replacement or work. I of course didn't know this when I had it installed!!
Old Apr 30, 2004 | 06:26 AM
Jsn350Z's Avatar
Jsn350Z
I asked my Nissan dealer if I could install it and still have it covered for warranty and they said it was not a problem.
Old Apr 30, 2004 | 06:33 AM
Tim'sZ's Avatar
Tim'sZ
I had the same problem after installing Test Pipes, I think the Test Pipes caused some fitament issues putting the exhaust a slight bind. Take it to a good welder that can weld Stainless and that will definitley cure your problem.
Old Apr 30, 2004 | 07:40 AM
mpowers's Avatar
mpowers
Can you post a pick with it installed on the car? It would be nice to see where the break is.
Old Apr 30, 2004 | 12:04 PM
DavesZ#3's Avatar
DavesZ#3
I believe if you install it yourself, it has a standard 1 year "parts" warranty. That is, NISMO will replace a defective part but you're still responsible for removal, installation, shipping, etc.
When the dealer installs it, you get a 3 year warranty for parts, labor, etc. just like any other Nissan factory installed part/option.
Old May 1, 2004 | 02:37 PM
greddy4777's Avatar
greddy4777
sorry to hear that man...as some one said earlier can u post some pics...i think i might have a leak as well
(when i let the rpms comes down..i hear hissing or air being released...thats a leak..right?)
Old May 1, 2004 | 03:33 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
meant to be a PM sorry
Old May 2, 2004 | 04:07 PM
denic79's Avatar
denic79
I never said where I bought it from.
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
