SES Light caused by my Kinetix Plenum
Old May 8, 2004 | 07:26 PM
xlacrosse's Avatar
xlacrosse
Default SES Light caused by my Kinetix Plenum
Hey Everyone ever since I installed my Kinetix V3 Plenum Ive been having the Service Engine Soon Light come on.
The Brass Elbow fitting behind the TB was actally blocked by some wierd material. So I yanked it out and drilled out whatever was in it and that solved my problem. I spoke to Kinetix about it and it seems to be an Isolated issue.
Heres a pic of what it looked like.
Old May 8, 2004 | 07:44 PM
alphared's Avatar
alphared
Default Re: SES Light caused by my Kinetix Plenum
Yeah ChrisM brought up the issue in his install plan a while back.
Old May 8, 2004 | 11:03 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
that looks completely blocked off... I wonder what it is? plastic cap?
Old May 9, 2004 | 12:01 AM
alphared's Avatar
alphared
Remember hearing that it was adhesive used to hole it to the block, like loctite or similar.
Old May 9, 2004 | 08:52 AM
jckolnturn's Avatar
jckolnturn
It's very important to inspect any part before installing, when i was putting on my NISMO intake i took one last look at the filter and noticed a piece of the packing foam was in the filter. What kinda damage do you think that would of caused?
Old May 9, 2004 | 10:00 AM
xlacrosse's Avatar
xlacrosse
dude your 100% right... problem is i never tought the brass nipple would be blocked... better luck next time.
Old May 11, 2004 | 11:47 AM
ChrisMCagle's Avatar
ChrisMCagle
Default Epoxy
Yeah, I had the same issue with my V1 plenum and sadly also with my V2. I've got pictures on my site of the glue in the fittings. On the V1, the coolant block was completely sealed with the epoxy they used to glue the fittings in. Also the fitting for the vacuum connection was plugged which threw a SES light on my car.
Luckily when I got the V2 I knew what to check and so after giving each fitting a check I found that the brake booster hose fitting was plugged so I just drilled it out and problem was solved. I've had the V2 on for a few months now with no problem (and no SES).
-Chris
Old May 11, 2004 | 12:46 PM
TheBigShow's Avatar
TheBigShow
do u think something like this could b causin my raspy, grinding sound between 2 and 3k rpm's?
Old May 11, 2004 | 02:17 PM
xlacrosse's Avatar
xlacrosse
doubt it ... it didnt cause any diffrence in sound or feeling after I fixed it... The only thing was that the SES light didnt come back on.
Old May 11, 2004 | 02:25 PM
ChrisMCagle
Default Doubtful
To be honest, I don't think so. I was running my V1 plenum for about a week and a half before I got a SES. The only thing I noticed was a rough idle that would run at about 700 rpms, then after about a 30-45 seconds it would bog down to less than 500 for about 20 seconds, then it would repeat the cycle again. I never heard any grinding noises. One possibility (however unlikely) is that the gluse was freed due to the vacuum of the intake and is flying around inside the plenum, but it would most likely have gotten sucked into one of the intake runners and caused some VERY noticible engine problems so I'd say that's not the case. The only real way to be sure is to do one of two things:
1. remove the plenum and check the brass fittings.
2. leave the plenum installed and pop off the hoses and blow into them one at a time and see if any are blocked. This might not be the best way, but it would save you the hassle of removing the plenum. The only ones you wouldn't be able to check this way are the 2 in the coolant block.
-Chris
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
wanderingstuden
Jan 28, 2016 07:03 PM
samansharif
Sep 25, 2015 12:31 PM
