Which is the best exhaust system?
Performance Nissan
Performance Nissan
Im sorry... Before tuning it made high 360 or low 370... after tuning it was above 380...
not my dyno sheets i havent had them infront of me to get the number burried into my skull...
Originally posted by PhoenixINX
Superchargers react entirely differently than turbos do on exhaust systems, exhaust pulses, etc... each have different needs, and react VERY differently to systems.
ok, I keep going back and forth on what to do on my car regaring the exhaust - here is my situation...
I am wanting to be as cost-conscience as possible (building a house right now) but I want a full system from the test pipes back... these are all the mods that I will eventually have by the end of the summer:
Pro-1 Intake
Custom Grounding Kit
Kinetix V3 Plenum
UR Crank Pulley
Helix Test Pipes
I would like to implement whatever exhaust combination that will yield the most power on an N/A car w/ these mods while canceling out the raspiness of the exhaust... the main question I have is: do I go w/ a true-dual setup like the Stillen design (w/ x-pipe), a true-dual setup like the Injen (no cross-over pipes) or do I replace the factory y-pipe and go w/ a stock-designed exhaust like the Fujitsubo/Nismo/Pro-1 V2/etc?
If the answer is true-dual, I am probably going to do a custom exhaust copying the stillen design but w/ Magnaflow SS products (X-pipe, resonators, 2-in 2-out muffler) - if the answer is stock-design, I am going to go with the 350Zforums new y-pipe (when it comes out) into a custom mid-pipe w/ resonator, into a Flowmaster 80 muffler.... like I said, saving $$$ while producing the most HP is the goal... thanks for the feedback (I'm sure this will be of benefit to many owners)
Pro-1 Intake
Kinetix V3 Plenum
UR Crank Pulley
Helix Test Pipes
Performance Nissan
Performance Nissan
Then you would be looking at the following exhausts in cost wize order less expensive to most... these are full cat back systems...
NISMO S-Tune Full Cat Back Including Y-Pipe
INJEN Straight Tip Full Cat Back True Dual
Apexi World Sport = Must Add Y-Pipe to get full cat back
FUJITSUBO Legalis R = Must add Y-Pipe to be full cat back system
Tanabe Super Medalion Racing = Must Add Y-Pipe to be full cat back
Justin100
Nov 29, 2015 03:58 PM
