"Y" pipe for nismo exhaust
Where can I get a "Y" pipe for my nismo exhaust, The flex on the right side of the pipe is rattling so I need to change the pipe. What is the best one to go with.
If the flex pipe is rattling then it is under warranty. Nismo provides a 36,000 mile warranty on S-tune parts. The part DOES NOT have to be installed by a dealership, it DOES need to be install properly by a certified mechanic. Nismo parts installed by the dealer also carry warranty on labor. Nismo part MUST be purchased through proper channels.
Nismo exhaust doesn't come with a y-pipe but if like shortcut3d said you had it installed by a certain protocol it should be covered under warranty. If not then a good and cheap y-pipe to look at is the JIC Y-pipe. I'm sure any of the vendors on this board can supply them.
japtrix sells y-pipes too. supposed to be modeled after the top secret y pipe at a much more reasonable cost.
http://www.japtrix.com/customparts.htm
looking for an exhaust to mount my y-pipe up to.
Justin100
Nov 29, 2015 03:58 PM
