Installed Kinetix cats tonight - fitment issue
Old Jul 2, 2004 | 01:19 AM
jreiter's Avatar
jreiter
Default Installed Kinetix cats tonight - fitment issue
Got my Kinetix cats installed tonight. Everything went well except that the fitment wasn't very good. They were close, but were angled just a little bit off. (Off by a few degrees too much.) This required us to really crank down the flanges between the cats and the y-pipe, causing a lot of strain to be put on the flex-pipe sections of the y-pipe. Basically, the flex-pipe was the only thing that allowed the cats to fit, and even then it was just barely. The flex-pipes are compressed and bowed out a bit (like they were inflated slightly). From other people's installs I've seen, the flex-pipe sections are straight and not curved, suggesting much less pressure on them then my installation has.
Anyway, it doesn't sound like there are any leaks, so I'm sure everything is connected snugly. I'm just worried about the strain on things and what it might do down the road, thousands of miles from now. (Cracking welds in flanges, etc.)
Anyone else have such fitment issues with Kinetix cats?
Old Jul 2, 2004 | 06:11 AM
ares's Avatar
ares
Veteran
Id call kinetix, cause if you go aftermarket exhaust, you wont nescessarily have that flex pipe section to take up the slack. with whats been going on around here... just IMO Id get the replacement now just incase.
Old Jul 2, 2004 | 09:01 AM
protocav's Avatar
protocav
i installed a set last weekend, and had fitment issues as well. all of the flanges lined up, but the heat shield on the cat was hitting the frame of the car. i had to take the cat out and "adjust" it with the hammer...
...needless to say, i wasn't impressed.
i have installed the helix test pipes, and the RT cats as well. both of these fit flawlessly.
Old Jul 2, 2004 | 10:40 AM
350Now's Avatar
350Now
I just installed the Kinetix Resonated pipe and the fitment was terrible. I had to have the shop make some modification to make this fit and not strain the y-pipe.
Old Jul 2, 2004 | 11:14 AM
lorinserbenz's Avatar
lorinserbenz
From experience with Corvettes I have put exhausts on, you might try and losing all the bolts for your exhaust system then tighten the Kinetix pieces first.
Old Jul 2, 2004 | 11:24 AM
Jax350z's Avatar
Jax350z
Has anyone had fitment issues with Kinetix cats and a Borla True Dual catback?
Old Jul 2, 2004 | 01:29 PM
ChrisMCagle's Avatar
ChrisMCagle
When I installed mine a few months back, I made sure not to tighten everything down until I had hand tightend all the bolts. The cats were tight, but I don't think there is any strain on the flex sections of the Y-pipe. One thing that I did have to do (about a week after the install) was to take a hammer and screwdriver and bend the heat shield on the car up and away from the cats. They were buzzing REAL bad on decel before I did that. Now it's quiet.
-Chris
Old Jul 2, 2004 | 01:47 PM
jreiter's Avatar
jreiter
Here is a very crude drawing I just did to show you the angle of things. You can see how this would cause a fair amount of strain on the flex pipes.
Attached Thumbnails Installed Kinetix cats tonight - fitment issue-kinetix_cat_fitment.gif
Old Jul 2, 2004 | 02:11 PM
ChrisMCagle
Yeah, based on your picture, I'd say that either the cats are't straight, or there is something holding them at the weird angle. Can you try loosening some of the bolts and see if that straightens things out?
-Chris
Old Jul 2, 2004 | 04:49 PM
jreiter's Avatar
jreiter
We did check the flange connections up on the exhaust manifold to make sure they were connected straight. Everything looked good there.
Old Jul 2, 2004 | 08:53 PM
350ed's Avatar
350ed
Professional
Many people have complained about the Kinetix CATs. That's why I went Crawford. Not sure why they haven't tried to fix the problem - too busy with plenums I guess.
Old Jul 2, 2004 | 10:10 PM
jreiter's Avatar
jreiter
Yeah, Crawford's was also on my list, but I couldn't find out which cat core they used. I emailed and got no response, and no one on the forums knew from what I could tell. That left me with Kinetix and Random Tech. I basically ended up going Kinetix because:
1) Kinetix uses Carsound cores, which are very nice.
2) There were numerous reports of failed Random Tech cats, and none from Kinetix. (Probably not a big deal, but it affects your decision when you're just about to buy one.)
3) The Kinetix were far less expensive.
Overall, the quality and build of the Kinetix units looks very good and solid. This fitment issue seems to be the only downside. Oh well.
Old Jul 2, 2004 | 11:04 PM
shortcut3d's Avatar
shortcut3d
Ultimate Racing cats use Carsound cores and the build quality is second to none. The price isn't bad to boot.
Old Jul 3, 2004 | 12:58 AM
fdao's Avatar
fdao
If I recalled correctly, the Crawford CATS uses Walker cores. Any Crawford guys out there can correct me if I am wrong.
fdao's Avatar
fdao
If I recall correctly, the Crawford CATS uses Walker cores. Any Crawford guys out there can correct me if I am wrong.
Old Jul 3, 2004 | 09:07 AM
350ed's Avatar
350ed
Professional
I hear ya. I wouldn't touch the RTs! Not a piece I want to swap every 6 months
For me the Crawfords were about the same price as Kinetix since I'm in CA (tax)
Not sure about the core, but haven't heard complaints about them thankfully.
Hope it works out for you.
Old Jul 3, 2004 | 01:32 PM
o snap its eric's Avatar
o snap its eric
had anyone put them up with the nismo exhuast?
Old Jul 3, 2004 | 01:52 PM
Zmego1985's Avatar
Zmego1985
Just go crawford i never hear complaints about them.
Old Jul 3, 2004 | 02:10 PM
mamboking's Avatar
mamboking
I just installed my crawford cats this morning. Originally, I thought of getting kinetix but after reading about all their customer support issues, I went with crawford. They fit perfectly. The alignment was right on.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Li1ag
Sep 28, 2015 02:07 PM
codek
Sep 28, 2015 03:03 AM
