resetting ECU with new plenum??
Old Jul 9, 2004 | 02:19 AM
Bahraini350Z's Avatar
Bahraini350Z
Question resetting ECU with new plenum??
Is it recomended to reset the ECU after fixing an aftermarket plenum"Kenetix"?? Or shall I just leave it to compensate for the change with time??!!
Advice is appreciated
Thanx
Old Jul 9, 2004 | 05:11 AM
jpc350z's Avatar
jpc350z
Default ECU Reset
I have installed and removed the plenum several times.. Each time I removed the negative battery terminal for several hours. After each re-install the car was fine..No lights and no loss of performance.
Old Jul 9, 2004 | 03:38 PM
Bahraini350Z
So, resetting is recomended?
Old Jul 9, 2004 | 03:44 PM
zzzya's Avatar
zzzya
I would recommend resetting and also performing the throttle positioning procedure from the Technosquare website if you unhooked the TB or disconnected the battery.
http://www.technosquareinc.com/350reset.htm
This is from the service manual.
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
