OFFICIAL Kinetix post, plenum issues, discussion etc.
deffinately no crack, for some reason you seem to be misenterpreting what myself and thezman were saying. we know the imperfection is not a crack. he thought that there were differences in some of the plenums & the plenums with the imperfection were a newer mold that didnt have the rubbing problem. then i answered him stating that i had this imperfection & the rubbing so his thoughts could not be true........again, were aware theres no crack & that there are rubbing issues with the v4 plenum due to potential thickness variences.......sorry for any confusion......
-justin
-justin
Justin is right. The only point of my post was to determine if we had a plenum from the same mold - i.e., if we both had a plenum with the imperfection. Since it appears that we do, it looks like I can expect a rubbing problem as well. I hope this clears things up.
[QUOTE I've heard that with F/I the plenum doesn't really add much anyway.
-Chris [/B][/QUOTE]
Chris,
This is not the only reason to upgrade the plenum.....especially with F/I applications. I believe, and correct me if I am wrong, that a concern with F/I and the stock plenum is equal distrubution of air to all cylinders, where the stock plenum fails. Even though HP gains would be minimal with F/I, the safety factor pays for itself many times over when it comes to these aftermarket plenums. Regardless if you like product A or B, I believe that a new plenum would be essential for F/I. I plan on going F/I very soon here and been researching the topic a bit. That being said, I want to go with an aluminum plenum when I go F/I, and I will definately give Kinetix a try becuase they have been very good with me and my plenums.
-Chris [/B][/QUOTE]
Chris,
Originally posted by maserom
I'm waiting to hear how the V4 works, before installing it. It is sitting in my garage for the past 2 weeks.
The only drawback is that the V4 has caused some rubbing of the hood on the engine cover and the actual plenum in some cases.
KINETIX is currently investigating what could be causing the problems.
you all will be happy with the perfromance results & the nice growl sound it adds at low rpms.......some have claimed they get no rubbing & some(as in my case) the rubbing is very light, almost nonexistant but its there, then the few who posted(pics) above that show aggressive rubbing.....non of the rubbing will affect performance.....im leaving mine on untill the FI plenum becomes available. they are in the testing stages now & if all goes well the FI plenums will be available later this month or early next month!! (o=
-justin
-justin
-justin
-justin
-Chris
i have been emailing with jamisonl and his last email(yesterday) stated they may(may being the majic word) have plenums available by the end of the month......only stating what ive heard, not trying to spread false info here.......either way its getting closer & is within reach!
-justin
-justin
Just so you guys know, Just like SungNamZ, I've been running the Kinetix with my Vortech. I've put about 1500 miles on it with the SC and I've had no issues. I'm running the v3 now, but I have a v4 sitting on the workbench too. So don't be afraid to use the plenum with FI, unless you plan on upping the boost above, say, 10 psi.
About the "rubbing", for those of you who see it first hand, would it help if we leave the cover off? If the plenum is touching the cover and the cover touching the hood, leaving the cover off might give it the few mm's it needs to barely touch until the problem gets resolved.
Just an idea.
Just an idea.
slaponte, that may help in some cases, the rubbing varies from not rubbing at all to heavy rubbing that may eventually cause problems with the plenums reliability. with my engine cover you can see it only hits cause the cover now bows a tad "up" in the center. i beleive if the cover were removed than it wouldnt rub the plenum. but i still have the plenum rubbing on the hood at another point so either way i have a problem......unfortunately everyones case will be a little different!
-justin
-justin
Should I use Black silicone or blue when putting the plenum on??
-Chris
I know that ZPresence paints plenums & does a great job. However, has anyone done a DIY? With what kind of paint & what process/colors?
Thanks!
Thanks!
