New Plenum ( APS )
Old Jul 16, 2004 | 05:23 AM
alininger2001's Avatar
alininger2001
I checked out their website that thing looks sweet. If you can stop drooling enough to read all the way to the bottom it says that a a strut bar is required for installation, sorry no stock strut bar for us.
Old Jul 21, 2004 | 12:20 AM
Z BOY's Avatar
Z BOY
Default Plus the strut bar!
Originally posted by AFitchTLS
Who has numbers on this? Which other 4 companies are coming out with plenums??
$375 is not a bad price at all and you get to keep your stock.
$375+cost of strut bar
Old Jul 21, 2004 | 03:00 PM
Jsn350Z's Avatar
Jsn350Z
The plenum looks computerized in those pictures.
Old Jul 21, 2004 | 04:23 PM
ares's Avatar
ares
Veteran
thats a cad drawing.
Old Jul 21, 2004 | 06:00 PM
raidersfan's Avatar
raidersfan
Ares, I tried installing an eggplant squash and i lost 10 whp and 8 fpt]
Old Jul 21, 2004 | 07:24 PM
Jung918's Avatar
Jung918
APS makes alot of quality products for the WRX/STI. I would consider this plenum over the others.
Old Jul 21, 2004 | 07:28 PM
ares's Avatar
ares
Veteran
you missing the turbo!
wrap it up nice and pretty though and I bet you can get 300 for it. just make sure it doesnt crack!
on second thought, that wont really hurt you.
Old Jul 21, 2004 | 08:49 PM
scz's Avatar
scz
Why would you NEED a strut bar when it looks like the plenum uses all of the stock bolt locations. What purpose would a "required" strut bar serve on a plenum.
Old Jul 21, 2004 | 08:58 PM
ares's Avatar
ares
Veteran
a strut bar isnt for the plenum, its for frame integrity. the plenum just keeps the strut from fitting across due to clearance.
Old Jul 21, 2004 | 10:23 PM
scz's Avatar
scz
Yeah, I understand what a strut bar is actually for, but why does it say 395+cost of the required strut bar?
Why is it required???
Old Jul 21, 2004 | 11:19 PM
black350's Avatar
black350
maybe cuz some people think handling is important.
Old Jul 22, 2004 | 04:30 AM
NismoKid's Avatar
NismoKid
They probably don't have that much margin on an aluminum plenum and requiring the bar would increase their profits. You don't really even need the strut bar on the stock car either. Not many people do enough spirited driving to cause enough chassis flex.
Old Jul 22, 2004 | 07:12 AM
jbenedict's Avatar
jbenedict
I beg to differ. Try taking your strut bar off and taking it for a spin around the block. You will notice a HUGE difference in body lean/chassis flex.
Old Jul 22, 2004 | 07:54 AM
ares's Avatar
ares
Veteran
oh, they probably mean required as in your old one wont work... so its required if you want a strut bar.
Old Jul 25, 2004 | 08:15 AM
NismoKid's Avatar
NismoKid
There's no huge difference. Read PhoenixINX's post. He's helped the Z community a lot with his part testing and input so I trust what he says: https://my350z.com/forum/showthread....threadid=84742
Old Jul 25, 2004 | 08:19 AM
jun14scr's Avatar
jun14scr
i have noticed no noticeable difference with the removal of my strut bar. sorry boys. and i do PLENTY of spirited driving.
Old Jul 25, 2004 | 09:56 AM
o snap its eric's Avatar
o snap its eric
so what phenix said was that the G35 did better than the Z in the salon pad because they dont have the brace?
Old Jul 25, 2004 | 10:13 AM
  #38
PhoenixINX's Avatar
PhoenixINX
No, I think it's based on the choice of tires for the G.
Not the obscense of the bar.
Old Jul 25, 2004 | 10:19 AM
  #39
o snap its eric
isnt the pilot sport pretty much like he SO-2? I've always wanted a strut for the G but no one makes one!
Old Jul 25, 2004 | 11:45 AM
  #40
Gsedan35's Avatar
Gsedan35
Simply stated, no one makes what can't be mounted. The G35 is not blessed with the required special welded on mounting tabs that the 350Z has. Now, you can waltz into your local Nissan dealer and buy the 350Z body panels that have the mounts ($219 X2) and have the mounts cut off and then welded onto the G35. The G has a few things in the way at the mount area you'd have to address first.
Also the G route's it's wiring harness differently then the Z across the front of the engine, right where the Crawford bar goes, you cannot simply pull it out of the way.
Your supposed to have a rear STB that is hidden out of sight on the G.
