kinetix cats rubbing under carriage
Old Aug 3, 2004 | 12:24 PM
BrImSt0ne's Avatar
BrImSt0ne
Default kinetix cats rubbing under carriage
I just installed these things on saturday and the cat under the passenger side is vibrating against the under carriage of the car. makes my car sound disgusting. . borla TD & kinetix cats = awesome sound, but all i hear is that damn rattle. is there anyone else from the GB that is having the same issue?
Old Aug 3, 2004 | 12:46 PM
ChrisMCagle's Avatar
ChrisMCagle
Yup! That's what mine did too. it's actually vibrating against the heat shields on either side. Here's how to fix it. Get a nice, big flathead screwdriver or preferably a crowbar and bend the heat shields up so that they are not touching the cats anymore. That is what I did and the vibration was gone.
-Chris
Old Aug 3, 2004 | 12:56 PM
BrImSt0ne's Avatar
BrImSt0ne
-Chris
Thx . Kinetix i am like the 3rd person to mention this, you guys may want to take another look at this. Your measurements may be off somewhere. I like the product though!
Old Aug 3, 2004 | 02:53 PM
ChrisMCagle
From what I have heard, they have fixed it. It used to be worse!
Old Aug 3, 2004 | 02:58 PM
Steel Heals's Avatar
Steel Heals
Brimstone - did you get the cats from the new jigs?
MIAPLAYA's Avatar
MIAPLAYA
Wow...nice...
Old Aug 3, 2004 | 06:25 PM
georgiaboy's Avatar
georgiaboy
i have the same issue and it gets really annoying? i ordered mine about 4 months ago. i have removed teh heatshield and it still rattles under there, any suggestion on how to fix it?
Old Aug 3, 2004 | 08:21 PM
AboostedG's Avatar
AboostedG
Twin Spoolin
I have the Kinetix Race Pipes w/ Resonators and no fitment issues at all. Also have the Japtrix Y-Pipe & RS-R ExMag GT2 Catback.
Sorry to hear your cats are rubbing.
Old Aug 3, 2004 | 08:52 PM
Zcool's Avatar
Zcool
I had mine installed today but immediately had them removed after the installer, a professional who only works on Z's, advised me that he didn't think that it was a good idea to install a product that had to be modified or required modifying the car in order to fit. Even after doing the alterations mention above the clearance would be still very close resulting in rattling or worse heat transfer for the cats to the floor board and a potential fire hazard.
My car is a roadster so maybe there is a difference from the coupe that we didn't know about.
Old Aug 6, 2004 | 08:41 PM
joe ahumada's Avatar
joe ahumada
I had the same problem after instaling mine last week. I called them and told them the situation and they are sending me out a new drivers side cat. It will be here next week. Hope it fits better than this one.
Old Aug 7, 2004 | 05:36 AM
jjellyneck's Avatar
jjellyneck
I bought a set of Kinetix cats--early versions, maybe a couple of weeks after they were announced. The drivers side cat would go up against the heat shield and the frame when accelerating, and I could not adjust it. I told Kinetix about the problem and my attempts to fix it. They sent me a new set with prepaid shipping (back to Kinetix) for the old set. The new cats fit perfectly, and I love 'em.
Old Aug 7, 2004 | 06:24 AM
lsdunique's Avatar
lsdunique
In all honesty, the damn cats have always been a tricky issue with us.
We couldnt figure it out at first, so we beefed up the JIGS.
It seemed like no matter what we did though, about 1 in 8 sets had fitment problems.
I just personally built some SERIOUS jigs before I went out of town last week. So while they weigh about 50 lbs each (1/2" steel) we think they have eliminated all possibility warpage.
We also made more room on the jigs for welding, so ALL of the welding is done completely on the jig and cooled before removal.
Quick question though, when you say it hits the floorboard or the heatshield, does it hit the catalytic converter shell higher up towards the engine?, or lower towards the ground?
Old Aug 7, 2004 | 06:28 AM
jjellyneck's Avatar
jjellyneck
Quick question though, when you say it hits the floorboard or the heatshield, does it hit the catalytic converter shell higher up towards the engine?, or lower towards the ground? [/B][/QUOTE]
On mine I believe it was in the middle, though maybe very slightly toward the engine end, if I remember correctly.
Old Aug 7, 2004 | 07:53 AM
ChrisMCagle
Mine was hitting the Cat shell near the header on both sides.
Old Aug 7, 2004 | 08:40 AM
TheBigShow's Avatar
TheBigShow
i don't think my cats r tappin, but my borla resonators r. shop will look at it wednesday, while it's in for some power pulls to check my a/f. the passenger side cat didn't bolt up to the transmission brace like it should have. is that what it is called? they r goin to fab out the bolt hole to get it in then. could stop the tappin, i hope.
Old Aug 7, 2004 | 09:25 AM
04evo2's Avatar
04evo2
left side of left cat and right side of right cat hits the heat shields when engine jumps. if you look under the car its only about an 1/8 of an inch away. mine is getting really annoying.
Old Aug 7, 2004 | 10:18 AM
lorinserbenz's Avatar
lorinserbenz
I think that person doing the install should keep all the bolts loose, then tighten one at a time checking for fitament issues.
I was big in to the Corvette (C4) scene and every time we changed something on the exhaust we had to loosen all the bolts and tighten once at a time checking for movement along the way.
Being that the Z/G cars have flex sections in the exhaust means movement is expected. I think that the flex sections might be the culprit behind the movement.
Maybe users of the cats can have the brackets cut of the stock cats and welded to the Kinetix cats, this would give perfect fitament.
Old Aug 7, 2004 | 02:19 PM
raidersfan's Avatar
raidersfan
mine fit like a glove.
Old Aug 7, 2004 | 02:33 PM
georgiaboy's Avatar
georgiaboy
lsduinque you have a PM, mine are really gettign annoying to!!
Old Aug 7, 2004 | 09:36 PM
BrImSt0ne's Avatar
BrImSt0ne
Here is a link to another post I made on how it was fixed.
Kinetix cat fix
