loss of power and real loud exhaust - any theories
Today I was driving my car and i got real loud (louder than normal) and i have a sense that i have lost power. The car just will not go. My two theories right now are:
1: exhaust components came loose - but that does not explain the loss of power (unless i have no backpressure and that is causing an issue.)
2: one / both of my rt cats collapsed
It is pouring down rain so i have not had a chance to look at it yet but i figured i would see if anyone had any ideas.
The sound comes from the middle of the car where the cat joins the borla exhaust. (see my sig for mods)
Thanks,
J
Thanks,
J
Originally posted by ChrisMCagle
Well, based on the number of failed RT's it may be that, but I'm not sure if that would make the exhaust louder. I am thinking that it's a leak somewhere.
-CHris
-CHris
Originally posted by JonathanG35
thanks for the input guys. I am going to try and get under it as soon as it stops raining. No matter what the case, I think it is time to put my clutch and flywheel in so everything may come off anyway.
-Chris
How loud, like annoying loud?
Two weeks ago I noticed that at idle my car sounded horrible. It was blatantly obvious that I had an exhaust leak. My Borla TD exhaust has cracked, and now I'm trying to contact borla to order that section of pipe that cracked.
If I were you, I'd turn the car on and do an outside inspection, just listen for a noticeable exhaust leak. If it is cracked or leaking you should hear the seeping pretty noticeably.
thanks for the help everyone.
the same exact thing happened to me today on my way to work, except i dont even have any cats. my idle is extremly loud now but i havnt noticed a particular loss in power. my car just sounds like an Indy car from 4000 rpms and up, also it backfires more than usual now. my guesses are a severe exhaust leak or something cracked open, please respon and tell me what you think.
BTW i have Helix test pipes...(only exhaust mod)
