Exhaust Gas Temperatures
Old Sep 30, 2004 | 12:29 AM
nitrous350's Avatar
nitrous350
Default Exhaust Gas Temperatures
i just install my Apexi EGT Gauge & Trans. Oil Temperature Gauge
how can i read this Gauges
rich temperature ??????
rean temperature?????
normal driving EG temperature ??????
and also what is my normal trans. oil temperature ????
Old Sep 30, 2004 | 02:22 AM
mchapman's Avatar
mchapman
For your setup who knows, assuming your car is tuned correctly you could just monitor the temps over a week and get an idea yourself of what normal for your car. Then if you see large fluctuations outside those values then you know somethings up.
Old Sep 30, 2004 | 04:02 AM
nitrous350's Avatar
nitrous350
Hey i just asking Help
any way Thank you
Old Sep 30, 2004 | 07:51 AM
Q45tech's Avatar
Q45tech
"Comparing EGT readings between engines whose EGT probes are not mounted exactly the same distance from the piston will get you in trouble. If you use EGT, mount the pickups in all your headers at the same length. Otherwise you might just misinterpret the readings."
Might find the folowing interesting:
http://www.maxracesoftware.com/egt_probes.htm
Old Sep 30, 2004 | 03:09 PM
nitrous350's Avatar
nitrous350
THANK YOU AND THANK'S
THIS IS WHAT I NEED MAN
liqalu04
Jan 2, 2022 12:58 PM
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
Li1ag
Sep 28, 2015 02:07 PM
