Should Crawford v5 plenum come with hardware?
Old Oct 15, 2004 | 06:45 PM
winw's Avatar
winw
Default Should Crawford v5 plenum come with hardware?
It came without washers, etc. The install instructions I've seen are for an older version. Am I supposed to have 2 10mm lock washer bolts?
Old Oct 17, 2004 | 10:09 AM
PhoenixINX's Avatar
PhoenixINX
Lock washers for the lower plenum... is this what you are referring to????
Old Oct 17, 2004 | 10:41 AM
G3po's Avatar
G3po
Default Re: Should Crawford v5 plenum come with hardware?
The four short bolts placed inside the plenum on the lower half (replaces) the long ones should have no washers , they come coated already with a thread lockre compound (so they can't back out). The two longer bolts in the center from the outside come with nylon washers (no lock washers). All the perimeter bolts (OEM ar re-used as is). You chsoul also have gotten an extra gasket, they should be "doubled up" , new ontop of old. Hope this all makes sense.
kgb
Sep 15, 2018 05:29 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
mcduck
Dec 18, 2003 07:11 PM
MustGoFastR
Oct 14, 2003 02:05 PM
whosdady
Aug 19, 2003 05:16 PM
