Crawford Cats+Borla TD+DC SS Headers
Old Nov 9, 2004 | 07:12 PM
alininger2001's Avatar
alininger2001
Default Crawford Cats+Borla TD+DC SS Headers
Hey guys, right now I have DC Sports headers and a Borla true dual exhaust, I am about to get the Crawford cats. Since the only bottleneck in my exhaust is the cats, am I in for a big increase in power? Maybe 10 more ponies? Is anyone running this combo, How will it change the sound?
Old Nov 10, 2004 | 05:02 PM
thaibox's Avatar
thaibox
I have the Borla TD and DC ceramic headers also. I too am in the market for a set of hi-flo cats. I have heard nothing but great things about the crawford cats. I wish I could get them, but they don't have c.a.r.b. approval. Big deal come around smog time here in Cali. That gives me the choice of either RT or UR cats. I have heard of too many problems with the RT cats and I havn't heard about anyone running UR cats.
Old Nov 10, 2004 | 05:42 PM
jjellyneck's Avatar
jjellyneck
Slap on a plenum and that should help out the intake side of the airflow.
I have cats as my only mod--I noticed more power from 2500 RPM upward. Not a lot of power, but enough to say that the mod was worth it for me.
Old Nov 10, 2004 | 07:24 PM
jreiter's Avatar
jreiter
For what it's worth, Kinetix cats use Carsound cores, which I believe are also CARB certified.
However, it doesn't matter. To my knowledge, in California you cannot replace your cats with aftermarket cats. The *only* time you can do so is if your factory cats failed, and you can no longer purchase factory cats for some reason. Only then can you use aftermarket cats. (And those have to be CARB certified, of course.) In the Z, even if your cats have honestly failed, you still are required by law to replace them with OEM cats since oem cats are certainly still available for this car. So, *any* aftermarket cat will cause you to fail the smog check in the Z. (assuming you actually get caught)
Old Nov 11, 2004 | 11:20 PM
thaibox's Avatar
thaibox
Thanks for the tip about the Kinetix cats. I'll look into those. I hope I don't have any troube with my dc headers come around smog time. I can hardly see them when I'm looking for them. Hopefully they wont notice.
Old Nov 12, 2004 | 03:46 PM
Jsn350Z's Avatar
Jsn350Z
For those of you worried about passing smog with the Crawfords.. Dont worry about it.
I had my car smog tested with the Crawford HF cats and Nismo exhaust and it passed with flying colors. The smog tech even said my car sounded great.
Old Nov 12, 2004 | 10:20 PM
jreiter's Avatar
jreiter
Aren't the DC headers for the 350Z CARB certified? I honestly don't know. I had mine coated by Jet-Hot in the black color to make them look as stock as possible.
Old Nov 12, 2004 | 10:22 PM
jreiter's Avatar
jreiter
Yeah, the Crawford and Kinetix cats both look pretty stock. Simple and unlabelled. That certainly must help with the visual check. I've seen some other posts around here from numerous folks with high flow cats who've past the sniffer test. It's really only the visual you have to worry about.
Old Nov 22, 2004 | 08:48 PM
Kid Thunder's Avatar
Kid Thunder
That's music to my ears. That changes my vote to Crawford cats.
Thank you
B Esquire
Sep 24, 2015 07:52 AM
z33z_nutz
Sep 23, 2015 07:22 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
EnjukuRacing
Sep 9, 2015 06:42 AM
