350z zex problem.. please help
Old Dec 13, 2004 | 02:38 PM
switchmaster's Avatar
switchmaster
Default 350z zex problem.. please help
Hello my name is Jeremey. I REALLY NEED YOU HELP, ASAP. I have called everwhere around here, and contacted zex. I have installed the zex wet system on my o3 nissan 350z. I DON’T know where to tie in my white wire to my tps sensor. I cant even find my tps sensor. I called the Nissan dealership, and they said it is all electronic, and there is no tps sensor or cable to the throttle body. My first question to you is where, and what color wire did you tie the wire into. I see where the so called tps sensor should be there is a wire harness with like 4 wires comeing out. What wire did you tie into to show the throttle open when the pedal is completely depressed. Second question where did you tie your fuel line at, and how. The nissan dealership said the fuel line has a pvc tube in it, so a t fitting wont work. I called zex and they said just experiment. I really need you help, and I just happened to see this when I went on google. Please send me pictures of your install, and any info that can help me with the fuel, and the tps white wire off of the zex sel. Thank you for your time, and I am really looking forward to your reply. Please email me at prb8shn@msn.com. I really need your help. Thanks. Jeremey
Old Dec 25, 2004 | 09:45 AM
rummya87's Avatar
rummya87
try the nitrous forum .... go to Engine/Drivetrain forum and click "nitrous" at the top! those guys know what they're doing and could surely help.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
