Tranny 2nd gear problem?
Old Dec 31, 2004 | 11:19 AM
rcheeker's Avatar
rcheeker
Default Tranny 2nd gear problem?
Fortunately, I have not had to have my tranny replaced...my car has a born-on-date of 4/04. Anyway, I seem to have a notch in second gear and only second gear. Doesn't matter if it's hot or cold. I can't tell if it's actually a grind or if this is normal. It's just not a very smooth shift. It doesn't cause me any problems and everything else works fine, but I wonder if it's the start of something bad? All of my other sports cars have been manuals, and maybe I just need to get used to this one, because it is definitely different.
Old Jan 7, 2005 | 06:11 PM
03daytonablue's Avatar
03daytonablue
I had my tranny replaced due to the 3rd gear grind. Now the new tranny has a very notchy 2nd gear almost like it grinds going into second but without the grinding sound. When it's cold you can feel it catching gear.
Old Jan 8, 2005 | 12:34 AM
rcheeker's Avatar
rcheeker
Thanks! So should I assume that this is normal? You described my issue perfectly.
Old Jan 12, 2005 | 05:17 AM
mpol99's Avatar
mpol99
That is what I love about the Z's transmission, the notchy feel!!! To me that feels awesome. Whats the mileage on your car? It will smooth out over time, but will always feel "notchy" (it is supposed to!)
On the other hand, if it GRINDS, get it tot he dealer. My car is on its 3rd transmission due to 2nd gear GRINDING. It has 17k miles.
Old Jan 12, 2005 | 08:26 AM
rcheeker's Avatar
rcheeker
I've got 4k miles. However, after reviewing many other posts, it seems as though the transmission is supposed to be smooth. The only "notchy" feeling I get is in second gear and all of the others are very smooth. Not to mention, that was the problem: I couldn't tell whether it was just notchy or if it is actual grinding. It seems to be a fine line and I was hoping that the other enthusiasts could help me come to a conclusion.
Old Jan 22, 2005 | 04:51 PM
zukbang's Avatar
zukbang
i also have the same problem...my second gear is very notchy...
only second gear..is this a known problem with the Z??or do i have to take it to the dealer?
i installed my b & m last week, do you guys think my b & m might cause this problem?all of my other gears are smooth..
help me out guys..thanks
Old Jan 22, 2005 | 04:55 PM
doodeitstom's Avatar
doodeitstom
I have a notchy 2nd gear and my tranny makes alot of noise. =/
Old Jan 22, 2005 | 06:25 PM
rcheeker's Avatar
rcheeker
I have the same problem without a B&M. Mine is still stock.
Old Jan 28, 2005 | 10:25 AM
daddyz's Avatar
daddyz
Mine wouldn't go in second.Replaced mine at 5800 miles.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
