Sevice Engine Soon
Old Feb 2, 2005 | 06:41 AM
Road Warrior's Avatar
Road Warrior
Default Sevice Engine Soon
is this normal...i have about 7100 mi and just noticed it this morning. i have done no mods lately but i do have some mods on my car. i am hoping there is like a service mark around this mileage and this is just an warning lite to have the service done.
anyone chime in with your comments....thanks
Old Feb 2, 2005 | 08:11 AM
Road Warrior
i called nissan....according to them this is not normal. i am going to check the gas cap and reset the ecu and see what happens. this sucks...hope its nothing serious. it did sound like my valves were clicking pretty good...maybe they need adjusting?
Old Feb 2, 2005 | 08:48 AM
350zluvr's Avatar
350zluvr
I have 19K miles on my Z and have an AEM CAI and S.S. and have not experienced this situation.
Good luck
Old Feb 2, 2005 | 09:00 AM
King Tut's Avatar
King Tut
I don't think it is the valves. For that light to come on some sensor must have put out a voltage that was outside the acceptable range thus making the ECU show you that light. The dealer should be able to hook up a code scanner and find out what code the ECU threw.
Old Feb 2, 2005 | 10:27 AM
bosotheclown2002's Avatar
bosotheclown2002
I have a '03 350Z and I had that problem once very early on after purchasing the car. The dealer reset the ECU ( at the same time I was getting the 3500 mile oil change ) and said it was because the gas cap was not on tight enough. I pointed out to them that I had been driving the daily car for two weeks since I last got gas but they did not have any other explaination.
It has never happened to me again.
Old Feb 2, 2005 | 10:44 AM
Road Warrior
i got gas about 4 days ago....i will check it out let you guys know...wierd stuff...hope its nothing major...thanks all for your input
Old Feb 2, 2005 | 10:57 AM
Road Warrior
i retightened the gas cap, disconnected the battery and its still coming on. i will disconnect the battery when i get home and see what happens tomorrow...maybe it needs a full reset.
i also have an appointment with the dealer so one way or the other i get this fixed....just hoping its nothing serious
Old Feb 3, 2005 | 06:37 AM
Road Warrior
well here is what i did: on my way home from work i filled up again....about 4 gallons or so to a full tank. then when i got home i disconnected the battery as i said i would in my previous post to reset the ecu. i hooked the battery back up this morning and whalla....SES light gone.
i don't think it was the gas cap as i ran the car down to 3/4 of a tank even before the SES light came on. i checked my manual and there is a 7500 mile service...i am wondering if this was the cause. however, the nissan dealership said it was not normal...maybe they were just trying to get me in to make some money. i am sure it would have just been a simple reset for them on their scanner since i was able to reset the ecu the manual way.
also, this morning the car seemed to run better too....i even smoked a 330 i coming in to work
peace out all....thanks for the responses....rw out
Old Feb 7, 2005 | 08:18 AM
cv_ryder's Avatar
cv_ryder
Check Engine Soon light came on in my 2004 Coupe, Touring 6MT, 10,500 miles last week after idling for 10-15 minutes while I defrosted snow and ice from the exterior. It stayed on for 2 days, or about 4 start/stop engine cycles, then went off and has stayed off. The owner's manual calls if a Malfunction Indicator Light (MIL) which should be checked out if it stays on. It recommends staying under 4,500 RPM, as it might be related to the emissions system.
Old Feb 7, 2005 | 03:08 PM
sinz's Avatar
sinz
Default service engine light
I have been having the problem off and on for the last year!! The dealer tells me the same thing -- that the gas cap is not on tight. I don't even think they know. Last time it happened it went off by itself . . . . Seems to be another problem with this car that can't be fixed.
Old Feb 11, 2005 | 12:15 PM
Netko350Z's Avatar
Netko350Z
You have to do more than just unhook the battery to reset the ECU. Run an internet search for "350Z ECU reset" and find out how to do it. I believe that on the TechnoSquare website they go over the procedure. It is one of those "Insert key...turn off...turn on..depress gas..etc"
Old Feb 11, 2005 | 12:45 PM
CinZ's Avatar
CinZ
I found out that there is a recall on this issue by Nissan. It has to do with the crank position sensor which is causing the service engine soon light to come on. This may create a no start condition and/or cause the engine to stop running without any warning. Looks like i'm taking it in to have it replaced just to be sure. Nissan Recall # 03V455000
Old Feb 12, 2005 | 01:34 PM
Pit Bull's Avatar
Pit Bull
Road Warrior, the light coming on means you are suppose to take your car into the dealer so they can scan it and determine what caused it. It's not something you try and figure out how to get around. If you start having chest pains (it might be a heart attack) but it sounds like you would ignore it. Use the dealer and the warranty, knowledge is power. Ignorance is bliss. You are now in a state of bliss, I hope your car doesn't have a heart attack and die. If it does please don't bash Nissan
Old Feb 13, 2005 | 09:17 AM
ants350's Avatar
ants350
The mil light will come on for a couple of issues the first is if their is a fault with a sensor not reading properly the second is if their is a leak in evap system such as gas cap being loose. The light will not come off right away will take any between 400-800 mi of normal driving and cycling of the ignition before it understands that everything is good or it has to get reset by dealer also when that light comes on the ecu goes into a fail safe mode and the car feels like it has a lose of power or dependeing on the code thrown will not even drive.
Old Feb 16, 2005 | 01:56 PM
tranzholik's Avatar
tranzholik
i have to same problem my car is around 7k miles.
dealer told me it was the gas cap....so i make sure it is tight after i fill up the gas everytime. the SES light still came back...this is the 3rd time.
Old Feb 22, 2005 | 11:58 PM
MySunset350Z's Avatar
MySunset350Z
this gas cap excuse is getting annoying. i bet nissan makes a manual for excuses to dump on its customers along with the service manual.
this gas cap thing is just the diahrea icing on crap cake nissan is selling. lol. sick i know.
Old Feb 23, 2005 | 06:53 AM
Road Warrior
the infamous SES light on my car has remained off btw...i have about 500 miles on it since i did the reset, another full tank of gas, and i had the oil changed at nissan too.
i know i could have taken the car in, but i don't like having to go to the dealer for anything....i figure if its something major the light will come back on and i will take the car in at that point. if i caused more harm by doing the reset myself oh well, everything is under warranty at this point.
look at all the TSB's that are out for the z...it would take you forever to fix them all...really sucks all the little things but i can live with most of them.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
