Rough Idle
Old Feb 11, 2005 | 11:44 PM
DAYTONA-ZED's Avatar
DAYTONA-ZED
Default Rough Idle
Anyone else here experience rough idle with the AC turned off. Was told by the service dept. that the idle is normal.
Old Feb 12, 2005 | 08:19 AM
NzZ's Avatar
NzZ
Default Re: Rough Idle
Yeah that is normal. It's true of most cars I've owned and driven.
NzZ
Old Feb 13, 2005 | 03:38 PM
shift_6x's Avatar
shift_6x
rough idle indeed can be normal, BUT, it doesn't meen it cannot be fixed. It can either be dirty fuel injectors (which is what fixed my idling problem) or it can be spark igniters causing slight misfiring. Other factors might play into why your engine or any engine for that matter idles so rough that the rpm gauge jumps, but for those who feel the need to do something about it, i would go with the fuel injectors first, dirty fuel is common and can cause problems to your engine as far as i am concerned. i hope i have helped out.
Old Mar 1, 2005 | 09:04 AM
palmerwmd's Avatar
palmerwmd
Mine did that the day I pulled out of dealership.
Was told its normal and drive it in some.
Stll there.
New dealer agrees its a problem despite not thorwing codes.
Is trying to fix.
They put in another MAF I am gonna see if it helped.
Fred..
Old Mar 1, 2005 | 09:55 PM
DAYTONA-ZED
Spark igniters? You mean spark plugs? That sounds like a timing issue.
Old Mar 1, 2005 | 10:02 PM
DAYTONA-ZED
Stll there.
Is trying to fix.
Fred..
Yeah i was given the same ******** line by my service dept, that the rough idle was normal.
At least your dept put in another computer control unit. The idle only needs to be raised 150-200 RPM to smooth it out. Hard to believe they designed a computer control unit that cannot be adjusted for idle. I understand the 350z may use the OBD II diagnostics as domestic cars ,but not sure about that.
Old Mar 7, 2005 | 01:53 PM
daveh's Avatar
daveh
Stll there.
Is trying to fix.
Fred..
Did the MAF sensor help with the rough idle? What year is your car.
They blamed my rough idle on my popcharger even though I had the rough idle before I installed it.
Old Mar 18, 2005 | 04:47 PM
JonsilvZ's Avatar
JonsilvZ
My Z idles very smooth. Have 24k miles. Can't hardly hear the engine idle when fully warmed up. I do drive it hard though.
Old Mar 18, 2005 | 07:54 PM
Ante Up's Avatar
Ante Up
man, finally a thread I can relate to. I have 4500 miles on my z and I have a rough idle as well. As a matter of fact, I can hear noise around the area where my clutch pedal is. My idle is always under 500 unless the A/C is on. Do your cars sometimes feel sluggish one day and run smooth on others?
liqalu04
Jan 2, 2022 12:58 PM
hulkout
Apr 28, 2017 09:00 PM
ablaine
Nov 29, 2016 10:13 AM
Darkspy
Sep 7, 2015 09:09 PM
