Redline transmission fluid
Old Sep 6, 2005 | 12:10 PM
LaPuLaPu's Avatar
LaPuLaPu
Will switching to an aftermarket transmission oil void the factory warranty?
Old Sep 6, 2005 | 12:14 PM
damfly's Avatar
damfly
Amzoil recommends their SVG (GL-5) severe gear lube first over AGL (GL-5) synthetic gear lube for passenger or racing applications. The only difference is in the weight. SVG is 75W90 and AGL is 80W90. I don't feel that the lower viscosity of the SVG is worthy of concern because of its superior lubricating qualities. Amzoil even lists SVG as a replacement for competitors 80W90 gear lubes.
I would be more concerned about using GL-4 in the manual trans and GL-5 in the differential. The GL-5 rating requires anti-slip additives for the clutch in the Z's differential. The manual trans has a "dry" clutch thus requiring only a GL-4 rated lube in the gear box.
Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 for the MT.
SEVERE GEAR 75W-90 Synthetic EP Lubricant for the DIFF.
I could be wrong but that's how I see it.
Old Sep 6, 2005 | 01:45 PM
Z'd's Avatar
Z'd
damfly- you are right on. Amsoil's new product "MTG" is now available for the MT:
http://www.amsoil.com/StoreFront/mtg.aspx
There are several options for the rear diff- I agree with your chioce.
lapham3
Oct 7, 2022 03:15 PM
07ZEKE
Aug 23, 2021 09:15 PM
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
