Only Change Oil Filter?
Old May 11, 2005 | 04:31 PM
jeffw's Avatar
jeffw
Default Only Change Oil Filter?
If I change just my oil filter and not my oil, how much oil should I expect to lose? I imagine the filter itself is full so that oil would need to be replaced. And I guess most of the oil will be in the oil pan. However, I'm wondering how much is backed up in the oil lines and fall out of the filter connector?
BTW, I'm contemplating using an extended oil change interval with synthetic and oil analysis service such as Blackstone. I understand this method still requires fairly regular filter changes.
Thanks,
Jeff
Old May 11, 2005 | 09:33 PM
yobri's Avatar
yobri
I would venture a guess at a quart. But to be safe, check your levels before putting more oil in...
Old May 12, 2005 | 04:51 AM
bigFenE's Avatar
bigFenE
change both oil and filter (synthetic that is) anywhere from 4-7k miles. I switched to sythetic once I was sure the engine had been completely broken in, for me that was 15k, my personal thoughts on when an engine is truly broken in on Dino oil.
Regards,
e
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
