Bose Stereo: Left Side Speakers Random On & Off
Old Mar 28, 2007 | 04:27 PM
  #41
doug's Avatar
doug
Originally Posted by SteveZ
At least if you go the adapter route, you can start with a good HU, upgrade components as you go. One of the dumbest threads I have seen is how to upgrade the system with $1000 of Infinity (Kappa) speakers that are compatible with the system. The HU is clearly the weak link.
If you search that thread you may also find links to face plate adapters for a double-DIN dash kit made for your car.
Not sure but just a guess the dealer will ask $500 if not more like $800 for the BOSE HU. Unless it was down around $200 I would not even consider replacing it out of warranty.
here are some of the pics... so far
Eclipse AVN-5510 - HU
FARENHEIT T-7000MHR 7" Screen - Cubby Hole
Rainbow Profi CS 265s - Components
(2) 10" Resonant Engineering SE Subs - Subs
US Amps Merlin MD43 - Components Amp
US Amps Merlin MD2D - Subwoofer Amp
Zenclosures Door Pods with Tweeters mounts
Zenclosures Dual 10" Sub Box for under strut bar
I maybe a little more than happy that my left speaker is going out
Old Mar 30, 2007 | 09:48 AM
  #42
webdk's Avatar
webdk
Hey any recommendations for HU.. All i need is something that plays MP3s.... I mean if there is a good deal for a nice one with a screen i will take that.. but overall any ideas? Also will need something compatible with IPOD
Old Mar 30, 2007 | 10:17 AM
  #43
nightcrawler_8's Avatar
nightcrawler_8
i fixed my problem by getting a CD changer that plays Mp3 and it works with the FM , so all the speakers are working fine .
done that cause am not soo into sound systems. i mean dont want louder than the bose.. just want the left speaker to work . so i guess this can be a turnaround way .
i will never get a relacment HU for 1700$ which may have the same problem after sometime.... i will never let the dealers fool me.
good luck guys
Old Apr 3, 2007 | 08:02 AM
  #44
infamous350's Avatar
infamous350
its not the headunit my 2003 bose did the same thing i recently replaced with a alpine 9855 thought it solved the problem but it happneed again yeseterday whiel i was drivin and my head unit is installed really good everything is soldered and hard wired so im stumped i think its the stock wiring from the headunit to the doors im gunna run new wires
Old Apr 5, 2007 | 04:42 PM
  #45
Z+Lotus+Vette's Avatar
Z+Lotus+Vette
I have the Pioneer Avic D1 and I too have the left speaker cutting out.
I figure either the Bose amp or the speaker, but has changing either one helped anybody?
thanks,
Rich
Old Apr 6, 2007 | 08:57 AM
  #46
Tekwon-V's Avatar
Tekwon-V
oh yea, in addition to getting a new headunit under the nissan warranty, i have another fix for this dreadfull problem - I MOVED TO CALIFORNIA. lol.
it seems like most of the problem is in the colder climate area.
Old Apr 10, 2007 | 12:48 PM
  #47
dayz's Avatar
dayz
I have the same problem with my bose system. The dealership replaced the speaker, and it worked for a couple days. Now it sounds worse/about the same as before. Grrrrrrrrr
Old Apr 11, 2007 | 06:23 AM
  #48
webdk's Avatar
webdk
Grr.. so what is the problem.. should i get new Kenwood.. and what if it will still continue to happen...?!?!
Old Apr 12, 2007 | 03:19 PM
  #49
kwadell's Avatar
kwadell
Default yahoo...got the BOSE fixed for free!
Wow, it's not often that I dealer takes care of you. I've got a 2003 Z. The 3/36 warranty is long gone. My left side channel had dropped out. With the CD player, little to no sound out of the left side with the balance set 100% to the left. With the radio on, you would get sound from both sides.
I took the Z in for an oil change and asked for them to have a quote on installing a new BOSE head unit. At noon, they called and told me they had finished the oil change. Then they said, if I leave the car there they'll fix the BOSE the next day FOR FREE! The service manager called Nissan and got approval to fix the stereo for free. So, just got it back and all is good. Both channels work. So, if you have the symptoms above it's probably the head unit.
Old Apr 13, 2007 | 05:17 AM
  #50
Z+Lotus+Vette
Kwadell,
Can you get the part number involved? I am betting it is the Bose Ampifier IN THE REAR, and NOT the head unit, since I changed out my head unit to a PIONEER and still experience the SAME PROBLEM.
Sorry about the caps, but I am frustrated...
Old Apr 13, 2007 | 05:19 AM
  #51
blasian's Avatar
blasian
I had this issue and replaced it with another Bose HU. Works perfect now.
Old Apr 13, 2007 | 05:00 PM
  #52
kwadell's Avatar
kwadell
Default BOSE head unit
It was definitely the head unit that they changed. Original unit had a small scratch and that is now gone. I'll dig up report and see if it shows the p/n. Both channels worked fine with the radio. It was only the CD channel that had the left side out. I'll also give it another 2 weeks to confirm the issue is 100% fixed.
Old Apr 17, 2007 | 02:33 PM
  #53
Z+Lotus+Vette
Went to the dealer and found out the dirt on this one:
The Bose recall involves the REAR amp, part # 28060CE400, retail price = $387. Turns out my car had this replaced under warrantee by the PO, but they will not make good a second time on it. I will likely do some research, as sometimes you can fix your own Bose amp by soldering the board.
Old Apr 20, 2007 | 12:14 PM
  #54
nadir's Avatar
nadir
the dealer replaced my headunit ... guy knew what the prob was without even checking my car .
Old Apr 24, 2007 | 04:49 PM
  #55
charged's Avatar
charged
I carbon fibered my center console and I am affraid of taking stereo out. The c/f is permanantly glued on, How to replace head unit???
Old May 23, 2007 | 02:32 PM
  #56
altinono's Avatar
altinono
same proplem i have left side speaker is off/on when the CD is playing
grrrrrrrrrrrrrrrrrrrrrrrr
grrrrrrrrrrrrrrrrr
grrrrrrrr
grrr
gr
Old Jun 2, 2007 | 11:28 AM
  #57
OffsetZ33's Avatar
OffsetZ33
I had the same problem - my left side was shorting out (and my headunit would skip sometimes - moreso when cold), and the dealership replaced it and so far so good...
Old Oct 28, 2009 | 06:37 AM
  #58
jubes's Avatar
jubes
thanks,
Rich
I'm getting the same issues now as well, but I don't have the stock HU, I have an aftermarket HU, and I took the car in to the dealer, they said it was the left front speaker, it worked for like a week or two then boom.. out again. They said they tested the amp, but like infamous, it worked great at some points and was crap in others... I honestly think its the amp, because if the OEM sub amp craps out like it does, who knows what Bose did to cut cost on developing the speaker amp as well
Old Apr 1, 2010 | 09:11 AM
  #59
siliconesteve's Avatar
siliconesteve
Default left speaker random off and on
Does anyone out there a definite fix for the left speaker random off and on? I would rather not buy an aftermarket headunit or amp if it will not fix the problem. Please Help.
Old Aug 2, 2012 | 12:37 AM
  #60
thespottedcow's Avatar
thespottedcow
Sorry to bump an ancient thread, but I didnt see a fix for this in this thread. I searched too but most people just replaced the head unit. I have an aftermarket headunit, and recently the drivers side speaker cuts in and out. Itll work fine, then Ill hit the brakes, and it doesnt want to work, and then randomly come back on. I havent pulled it apart to check to see if theres a loose connection, wanted to avoid pulling the wiring apart more than I had to. Im tempted to just get new speakers, but Ive heard wiring them is a pain :/ Any help is appreciated
