Bose Stereo: Left Side Speakers Random On & Off
Old Jul 23, 2005 | 09:07 PM
Tekwon-V's Avatar
Tekwon-V
Default Bose Stereo: Left Side Speakers Random On & Off
the left side (the "big" door speaker and the tweeter) would go out, but not completely. when this happens, i put the balance all the way to the left (to check) and the sound barely comes out and the sound is horrible... almost like a blown speaker. it's like a cellphone reception breaking up real bad.
and later in the day, it will randomly work fine. so it cant be a blown speaker. when it works, it works great (for a bose anyway )
and it never goes out WHILE i am listening. it's "determined" when i turn on the stereo.
so i am thinking it's a bad connection or the headunit itself. i want to try to fix it myself before taking it to the dealer because 1. it will probably work fine if i take it in with an appointment, 2. want to save time.
anybody have a good advice/experience?
Old Jul 23, 2005 | 09:13 PM
rbaggett1's Avatar
rbaggett1
Hey Tekwon-V,
I took in my car earlier today because of a handful of issues, but one of them happened to be this as well. My CDs would sound really bad and muddy. Almost like the treble was way low. Sometimes the audio was really weak from the left channel like you mentioned earlier. Sometimes the stereo would work fine, sometimes it wouldn't. It really got on my nerves.
They replaced out my headunit and everything is good to go. I originally thought it was a loose connector as well, but I was sitting at a red light and bam; the volume got really loud.
You might just have to replace it out like me. Good luck.
Old Jul 23, 2005 | 09:18 PM
the7ferret's Avatar
the7ferret
short
bad headunit
Old Jul 23, 2005 | 09:20 PM
Tekwon-V's Avatar
Tekwon-V
oh ok. so i guess it is the headunit then. shoot, i guess i will call the dealer first thing on monday. sigh.
Old Jul 24, 2005 | 04:13 AM
rbaggett1's Avatar
rbaggett1
Originally Posted by the7ferret
short
bad headunit
Bad headunit so far, but I only had the car back for a day. So I'll know in a week after sometime with the car.
Old Jul 28, 2005 | 04:01 PM
rbaggett1's Avatar
rbaggett1
My new headunit seems to be holding up pretty good ever since it was replaced.
Old Jul 29, 2005 | 10:25 AM
BriA5's Avatar
BriA5
I've been having the same problem for the last two weeks or so.
I guess I will have to call the dealer. Do you think I will be able to convice them to order me a new HU over the phone? or will I have to waste two days for this (one to check it out and one to make the swap once the HU comes in).
Old Jul 29, 2005 | 12:03 PM
rbaggett1's Avatar
rbaggett1
I guess it all depends on your dealership. They know there is an issue with these stereos since it's happened before with other customers. I had the car in for some other issues and they just quickly tested it. I guess when this falls out of warranty, I'll be in the market to replace everything out (that's audio related).
Old Aug 14, 2005 | 09:08 AM
rbaggett1's Avatar
rbaggett1
Darn it. I'm getting the same condition you had Tekwon-V. The left channels sound like bad cell phone reception. So even with a replaced headunit, I'm having problems again. I'll drop it off Monday.
Old Aug 15, 2005 | 01:42 PM
rbaggett1's Avatar
rbaggett1
I talked to the service advisor this morning and he mentioned that I should get a CD Player Lens Cleaner to fix this problem. I'll pick that up tomorrow.
Old Aug 15, 2005 | 03:10 PM
barthelb's Avatar
barthelb
Master
Hmm I'll try that. I have this problem as well. I got fed up on Sat and went to the dealer and scheduled a service on Thrs.
I also have an intermittent problem with the drivers seat back power switch.
The axles click as well. All those need is to be taken off. Re-greased with another grease and re-torqued.
Old Aug 15, 2005 | 03:18 PM
rbaggett1's Avatar
rbaggett1
My rear axle is clicking as well. I took it in to get it worked on but am not sure if they did it or not. I had it in there for some other work as well.
Old Aug 19, 2005 | 01:58 AM
jonghj's Avatar
jonghj
I have exactly the same problem. Bose, left speaker!!! with radio on all speakers works fine, but with cd on left side speakers are retarded. this headunit randomly does that.
Also I did the lens cleaning!! it didn't work!!
Old Aug 19, 2005 | 09:33 AM
rbaggett1's Avatar
rbaggett1
I went ahead and got the lens cleaner a couple days ago. It didn't seem to work. It seems to randomly drop the left channel (almost like loose wiring). Also when I was listening to the CDs, my little speaker right the side mirror doesn't seem like it's even hooked up on the left side. The right side is perfectly fine. Go figure.
Old Jul 20, 2006 | 05:35 PM
reptile718's Avatar
reptile718
I know this is an old thread but I could not find any other info on this problem. It just happened to me today, driving down the road and bam left side went out. In radio mode everything was fine. I figured out that when I hit the drivers of the center console the sound comes back but only until I change the disc or turn the system off then it goes back to that faded blurry sound. Did you guys ever figure out what the problem was? I am thinking loose connector either in the outside of the bose unit or inside, maybe some ribbon inside got pinched or melted Any suggestions would help, thanks!
Old Jul 20, 2006 | 08:31 PM
Tekwon-V's Avatar
Tekwon-V
it's DEFINATELY the head unit. they label it under "internal problems" and replace your head unit.
they replace it with a refurbished unit, so make sure you are happy with the new/replacement one... like on the display "screen", make sure you dont have scratches. mine did and i asked for a different one.
Old Jul 21, 2006 | 06:37 AM
alnfong's Avatar
alnfong
I've replaced my head-unit 3 f**king times.And i finally got a good one(with no problem at all.)
Old Jul 26, 2006 | 12:04 PM
woo_z's Avatar
woo_z
I had this problem a few weeks ago. While listening to a CD, the left side speakers just died. If I switched to radio, it worked fine. Someone mentioned it was a bad amplifier. My Z is out of warranty, so that blows.
In any case, about a week later, the sound mysteriously came back on, and it's been fine ever since.
p.s. I hate to say it - I traded my Z in. This is my last week with it. I'll miss it, but I'm sick of the problems.
Old Sep 26, 2006 | 10:07 AM
ZLadie2000's Avatar
ZLadie2000
i HAVE THIS PROBLEM TOO! But Nissan is replacing my left speaker tomorrow under warranty...
Old Jan 18, 2007 | 08:23 PM
davewo's Avatar
davewo
Default Bose left speaker going out
Having exact same problem on my 2004 roadster. Did replacing only the left speaker work?
