Gear hitting sound when it's Idle
Old Aug 9, 2005 | 09:25 AM
doreamon50's Avatar
doreamon50
Default Gear hitting sound when it's Idle
Today while I was starting up my car, I could hear a popping sound coming from underneth the shifter, when my car it's idle while I'm sitting in the car. So then I got out the car and lay down on the ground next to the driver side door to hear it better. I could hear gear hitting sound coming out infront of the Y pipe, around the tranny area. Do you guys have this problem with your Z?? I got Manual.
I made an appiontment to have my car go in tomorrow already, but I've took my car in to the dealer for tranny problem for 6 times already, each time with different issue, but everytime they just tells me that "theres no problem with the car, that's the way the car it's desgin" I'm afraid they gonna tell me the same this time. What should I do if they tell me that again.
Old Aug 9, 2005 | 10:17 AM
King Tut's Avatar
King Tut
They are definitely going to tell you that again as the car does making a popping sound from near the cats when it is at idle. I would suggest you relax and enjoy the drive instead of straining your ears listening for every bump, rattle, and pop so you can take it to the dealer.
Old Aug 9, 2005 | 10:47 AM
Fletch69z's Avatar
Fletch69z
The transmission on our cars is a pretty loud one. Unless performance is affected I or there is a really loud noise I would say it's probably normal.
Old Aug 18, 2005 | 08:20 AM
yr4m2's Avatar
yr4m2
Default "Normal"
I took my car in for the noise yesterday. If you turn off the car while it is in neutral, the noise is really loud, as it is on mine. The dealer stated it's the pressure plate, and is completely normal. I had him start a brand new Z to convince me. Although the sound was less, it definetly was there.
Damo
Old Aug 22, 2005 | 09:05 PM
DtyBlu350's Avatar
DtyBlu350
Mine does the same thing, ill put out of gear and turn it off and almost everytime it makes this load rattle like noise near my shifter, it dosnt seem to be causing any problems but it still kinda worries me
Old Aug 22, 2005 | 09:08 PM
cloudy's Avatar
cloudy
Keep it in 1st or R when you turn the car off and see if it still does it .
Old Aug 22, 2005 | 09:46 PM
Timmy_boy188's Avatar
Timmy_boy188
ahh, this stuff makes me happy to be switching out to a G tomorow
Old Aug 22, 2005 | 10:11 PM
atar350's Avatar
atar350
Isnt the transmission and motor exactly the same? I would think you wouldnt hear it AS much in a G then a Z, there is alot more car to that thing, and probably more sound material. Why knock the Z?
Old Aug 23, 2005 | 11:34 AM
cloudy's Avatar
cloudy
Ya what'd you think the G transmission was different? lol
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
