Squeaking noise when gasing
Old Sep 18, 2005 | 10:46 AM
gsazabi's Avatar
gsazabi
Default Squeaking noise when gasing
Last night my Z developed a new squeak noise, and I made a post about it,
thinking that the squeak is coming from the clutch pedal when letting out after upshifts.
I was wrong.
I drove the car today and the squeak noise
is NOT coming from clutch pedal. In fact the clutch
is completely normal.
However, I noticed that the squeak noise comes
when I push the ACCELERATOR.
So everytime I shift and put my foot back on the gas,
it sounds like a cricket is inside my car lol.
It also makes that noise every time I tap the gas.
It seems to be coming out from the front/engine bay area.
Your inputs/help appreciated.
Old Sep 18, 2005 | 02:11 PM
plumpzz's Avatar
plumpzz
Maybe a family of crickets have found a nice warm place inside your plenum mwuahah
Old Sep 18, 2005 | 06:17 PM
halitosis's Avatar
halitosis
gsazabi,
whoa, I am hearing the same thing. Does anyone else know more about this? It really sounds like a wastegate noise (but much fainter.) Happens to me a WOT.
Old Sep 18, 2005 | 08:22 PM
gsazabi's Avatar
gsazabi
Originally Posted by halitosis
gsazabi,
Haha it does sound like wastegate noise - but tiny, puny one lol
Weird it happens to you at WOT. Mine does it everytime I step on the gas to give it some throttle.
Well I've talked to Jason and here's what he said:
"It sounds like your throttle body opening up and air rushing through your intake filter...
its like a high pitched PSSCHP that happens really quick... Its the initial rush of air through your intake.. It does with with the factory intake as well as aftermarket... you hear it mroe with aftermarket intakes..."
So I guess it seems normal...weird that it never happened before until last night...
Old Sep 19, 2005 | 05:46 AM
King Tut's Avatar
King Tut
Normal.
Old Sep 21, 2005 | 07:58 AM
johnk024's Avatar
johnk024
Do you have a CAI?
Old Sep 21, 2005 | 07:32 PM
RacerX's Avatar
RacerX
"Squeaking noise when gasing"
What did you have for lunch?...
Old Sep 21, 2005 | 08:50 PM
Exta_Z's Avatar
Exta_Z
Its the parking brake bracket underneath the car...its a common issue on the Murano's and Titan's too. Takes about 45min to fix...known issue no big deal! Also, the techs are instructed to check the rear axles as well while performing this diagnostics!
Old Sep 22, 2005 | 02:37 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Sounds like you have some type of aftermarket intake. Mine makes a "squeaking" noise when I hit the gas and can be heard even better at around 4000 rpm.
Old Oct 14, 2005 | 01:04 PM
halitosis's Avatar
halitosis
Yeah, posted on this thread earlier, but after installing the JWT Pop Charger, I realized that the noise was just the intake air flow.
Old Nov 26, 2005 | 05:47 AM
En-GLaived's Avatar
En-GLaived
Hmm, I think I have this noise also but mine seems to be more of a metal tinking noise almost more than a squek, but it happens when I get on the gas. Is this the same noise or something else?
Old Dec 8, 2005 | 02:24 PM
MarlboroMan's Avatar
MarlboroMan
I installed the popcharger this past weekend and immediately heard the same kind of noise. But it's so faint that I only hear it with the windows down.
Old Apr 17, 2009 | 04:42 PM
Ezra's Avatar
Ezra
I have the stock intake and I just started noticing this as well... I can even park the car, put it in neutral and rev up and i can hear it squeak around 4000 rpm too.
Old Apr 18, 2009 | 09:17 PM
cipher's Avatar
cipher
throw out bearing? are u sure it isnt coming from the clutch?
Old Apr 19, 2009 | 06:21 AM
Spork's Avatar
Spork
Is it a squeak? or a chirp/whistle?
Old Apr 19, 2009 | 06:53 AM
=Cerberus='s Avatar
=Cerberus=
I am betting it is a whistle, I hear it as well when I blip the throttle. I didn't notice it till after I put a plenum spacer in so I thought I had a leak, but after listening to it closely (and checking the torque on the screws), it was from the airbox.
Old Apr 19, 2009 | 09:17 AM
j.arnaldo's Avatar
j.arnaldo
That's g-a-s-s-i-n-g.
Old Apr 19, 2009 | 03:21 PM
Ezra's Avatar
Ezra
It's more like a chirp. I know what you are talking about when you blip the gas, I have that too, but that's not it. Its more of a chirp from 3,000 - 4,000 rpm as you gradually increase the gas. If you gun it, you don't hear it at all, but its when you gradually approach the 3-4k range is when it chirps. I don't think it's the throwout bearing as you can replicate this sound by reving in neutral with the clutch disengaged as well as engaged. I almost want to say its the belts.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
