when coasting...
Old Dec 18, 2002 | 09:46 PM
ares's Avatar
ares
Veteran
Default when coasting...
when Im coasting down my driveway foward or backword, I sometimes hear a sound as tho I just scraped my bumper on the ground. but I didnt. it happens when the car is in gear, cluth out, so just using engine braking, and then you heard "grind" just for about a second or less, then it stops, no noticable difference in speed.
anyone else get this?
Old Dec 22, 2002 | 01:35 PM
VandyZ's Avatar
VandyZ
Yes, I get this too. Mine happens when down shifting to slow down. I get it as the RPM's go from +4000 then at about 4000 I hear and feel a . . . well hard to describe. I had a honda person with me the last time I did it and he said it was the cam profile changing. I dont know. I dont do it often enough to worry about it or feel it does damage to any thing. Just sounds a little akward.
Old Dec 22, 2002 | 03:01 PM
westpak's Avatar
westpak
SFZCC
I get a similar noise when in gear and coasting while I go between 4000 down to 3000 in 2nd or 3rd gear, the problem is that I can't repeat with consistency. The sound and feel as mentioned is hard to describe but to me it seems like a shudder or vibration that lasts only for a second. I figured it probably isn't the driveshaft or it would do it all of the time but I have no clue, I took the tech for a ride and I could not duplicate it, so I guess I wont worry yet unless it really becomes more regular.
Old Dec 23, 2002 | 12:54 PM
Gators's Avatar
Gators
I had the same problem while coasting down the ramp in my parking garage at work. I knew I couldn't be scraping the bumper since I take the same route everyday, but that is close to what the grinding sounded like. Please let us know if anyone figures out what causes this.
Old Dec 23, 2002 | 06:00 PM
Flyingscot's Avatar
Flyingscot
Is it possibly the sound of the brakes dragging? I hear this on my other two cars if I crawl slow enough. With the sound proofing removed from one of my cars, it is very apparent on the rears.
Fly
ares
Jan 18, 2004 04:41 PM
