Dealer Rip Off!
Old Oct 11, 2005 | 04:33 PM
NiSmO21z's Avatar
NiSmO21z
Angry Dealer Rip Off!
While putting on my plenum spacer, one of the center bolt for my upper plenum broke off. Took it to dealer to see if they can drill it out. Supposably they can't and wanna charge me 300 for a lower plenum. Total being $600 w/ labor. BS! Goin to drill try drillin it out myself, if not just buying the kinitex plenum, which you don't need the top bolts. How many lbs of pressure, do you use for the plenum bolts?
Old Oct 11, 2005 | 04:44 PM
DavesZ#3's Avatar
DavesZ#3
Go the Sears and get a bolt extractor kit and do it yourself.
Those 6 bolts on the center of the plenum are supposed to be torqued to 9-10 ft-lbs or 108-120 in-lbs. Note, that's 120 IN-lbs, if you accidently try 120 ft-lbs you'll definitely break one.
Also, there's been a lot of discussion regarding this in the Modification>Engine/Drivetrain/F-I forum with a number of suggestions being made. Make sure your engine is cold when you try to remove and re-tighten those bolts. Also tighten them in steps. For example, tighten them all to 30 in-lbs, then go thru them again tightening to 60 in-lbs then do the final tighten to 120 in-lbs.
Old Oct 11, 2005 | 06:53 PM
Robz33's Avatar
Robz33
better yet go to a fastener store, or some where that sells left handed drill bits, they work much better than extractors.
Old Oct 12, 2005 | 09:16 AM
NiSmO21z's Avatar
NiSmO21z
Thanks alot Dave for the info.......
Old Oct 12, 2005 | 10:48 AM
the7ferret's Avatar
the7ferret
If you have the motordyne spacer with the internal supports you can torque them to 120in lbs easy.
If you have the AAM Angled spacer which dosent come with the internal supports torque then to 60 in lbs MAX!!! I tried 120 and cracked my plenum.
Pleask
Dec 21, 2021 03:17 PM
07ZEKE
Aug 23, 2021 09:15 PM
3vilbunny
Jul 18, 2017 05:10 PM
ablaine
Nov 29, 2016 10:13 AM
Juztin
Nov 22, 2015 07:03 AM
