Help me remove my battery
Old Nov 22, 2005 | 04:27 AM
DanOnTheRoad's Avatar
DanOnTheRoad
Default Help me remove my battery
So I'm preping my 05 roadster for it's winter sleep and go to remove the battery. Easier said than done?
The casing around it seems to be held on by very strong clips. Should I just pull on them until they pop, or is there some sort of trick to them? Obviously, I don't want to break the clips.
I know I could just buy a battery safer but it's much cheaper to simply remove the battery and put it in my basement on a piece of wood. It's worked many other years with other cars. Reconnect it in the spring, and pow, it starts on the first turn.
Old Nov 22, 2005 | 08:42 AM
DavesZ#3's Avatar
DavesZ#3
Don't force the clips. If I remember, they are the kind that have a little center plunger that you have to pop it up first then the big outer clip will slide out of the hole. Try a small screwdriver to lift the center pin of the clip.
Old Nov 22, 2005 | 01:02 PM
DanOnTheRoad
Thanks. I'll have to try that. It's damn cold here though.
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
