HID Pattern
Old Jan 5, 2006 | 11:06 AM
umzzz's Avatar
umzzz
Cwest Army
Default HID Pattern
i recently opened up my headlights to change out the amber strip to a clear one. Everything went well no fogging or anything but not my HID pattern is not flat and linear like all the picstures people have posted od their beams. to be honest i dont think they ever really were nice and flat. any suggestions on how to fix this. the pattern currently is kind of blotchy and all over the place. I see the hot spots and all but theres a good amount of light over and around that as well. ill try and get pics up later on.
any suggestions.
is it possible to install the hid bulb upside down is there a certain orientation it should have?
thanks
Old Apr 4, 2006 | 11:08 AM
Catch22's Avatar
Catch22
actually, i need this same answer... my left light is nice and flat but the right one is skatterd all over the place...i have opened up the headlight once to fix this problem but failed evidently
how should the bulb be positioned when in the housing?
Old Apr 5, 2006 | 09:05 AM
Catch22's Avatar
Catch22
Originally Posted by mc350z
are you talking about the "dip" in the cut off line that looks like this?
_____------- _____-------
correct, i have an 03 so its not perfect no mater what i do... but my right one is horrid... there is a huge amount of light projected downward just infront of the car and then some also projects outward but not in a set pattern
Old Apr 5, 2006 | 01:59 PM
Catch22's Avatar
Catch22
ive also heard the driver side light is aimed slightly lower from the factory due to oncomming traffic.
yeah i understand that, ill see if i can get some pictures later on tonight when it gets dark.. believe me its not normal
but if you know how the bulp is supposed to be seated that would be nice too... on the bulb i have it has a brown tubular wire running above and parallel with the glass itself, does the rotation of the bulb affect the beam... should this wire be at a certian orientation when inserting the bulb?
Old Apr 5, 2006 | 07:50 PM
Catch22's Avatar
Catch22
pictures would be helpful
ill see what i can do tomorrow.. dont have a digi cam at the moment cause i was an idiot on new years
Pleask
Dec 21, 2021 03:17 PM
Paul.
Oct 16, 2015 07:34 PM
M Powered
Dec 8, 2002 11:04 AM
danringer
Cleaning & Detailing
30
Oct 3, 2002 06:45 PM
