How do i fix a hole in my gas tank???
Old Feb 14, 2006 | 07:40 AM
Srivero297's Avatar
Srivero297
Unhappy How do i fix a hole in my gas tank???
so basically, I have a drill hole in my gas tank....
Yeah, dont ask its a painful story...
Anyway, I tried threading a slightly bigger screw soaked in silicon hoping that it would seal the hole, but no luck because my interior still gets gas fumes. Im thinking maybe the gasoline dissolves the silicon??
I dont want to weld over the hole because, well.. sparks.. gasoline.. Yeah.
And if you recommend taking the tank down to fix it, have you ever seen exactly where our tank is?? It straddles the transmission, meaning to take the tank down in one piece you actually need to take the transmission out first.. So id like to avoid doing that if its at all possible.
Is there any kind of apoxy sealant perhaps or any other way I can seal a hole in my gas tank?? I need help badly...
Old Feb 14, 2006 | 09:11 AM
superchargedg's Avatar
superchargedg
Damn Noobs
icant remember but if its a steel tank it has to be taken out and welded,but if its a plastic tank,there are all kinds of epoxies that should work(pep boys,autozone will have them)silicone def doesent work.good luck
Old Feb 14, 2006 | 09:20 AM
DavesZ#3's Avatar
DavesZ#3
JBWeld - it seems to work for just about anything else, not sure if it's gasoline proof though.
Old Feb 16, 2006 | 04:31 PM
maximumsportZ's Avatar
maximumsportZ
I had the similar problem also, just use some expoxy that thing is strong.
Old Feb 19, 2006 | 07:37 PM
jinsei888's Avatar
jinsei888
lol pwn3d
Old Feb 19, 2006 | 07:45 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
were you installing a stereo system?
Old Feb 19, 2006 | 07:53 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
yeah you gotta tell us what happend?
Old Feb 21, 2006 | 02:33 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
True, epoxy is strong.
But don't forget that gasoline is an organic / nonpolar solvent and it will basically eat through a lot of different materials that you might not expect.
I would get some kind of disposable muffin tin from the store, then put the epoxy on something and put it in one of the muffin holders along with some gasoline. You can basically check to make sure it will hold up.
Old Feb 21, 2006 | 09:50 AM
mchong75's Avatar
mchong75
Nothing DUCT TAPE can't fix.
Old Feb 21, 2006 | 10:00 AM
michaeljr6's Avatar
michaeljr6
+10000
Old Feb 21, 2006 | 10:19 AM
ClaytonC01's Avatar
ClaytonC01
our cars have plastic tanks dont they? if they do, im sure theres a type of epoxy thats holds up to gas. and fyi the safest way to weld a steel tank, is when its full of gas, less fumes.
Old Feb 21, 2006 | 10:21 AM
rxtrom's Avatar
rxtrom
Fix a flat??
j/k that stuff sucks.
Is it on the bottom or the top of the tank??
Big diff, b/c either it will be holding in all the gas, or just sealing the fumes.
Old Feb 21, 2006 | 10:24 AM
rxtrom's Avatar
rxtrom
I hope you are joking. B/c if a tank needs to be welded it would be b/c it has a HOLE in it. Thus the uncomfortable situation of keeping it filled.
Old Feb 21, 2006 | 11:51 PM
derek173's Avatar
derek173
Great stuff!!!
Drain tank so hole is not leaking and jb weld it!
Old Feb 22, 2006 | 03:32 PM
dkmura's Avatar
dkmura
General & DIY Moderator
IMHO this is not a good situation- if any of the temporary fixes start to leak, fumes are the least of your worries. This could be catastrophic since a fuel leak could start in an accident and burn your Z to the ground. I wouldn't take any half measures- pull the tank, drain it and either get it properly welded or replaced!
Old Feb 22, 2006 | 04:34 PM
KornerCarver's Avatar
KornerCarver
I think they usually fill a steel tank with water when welding it. 20 gallons of gasoline could make quite an explosion. Anyway, I suggest getting the tank repaired properly or replacing it. Don't take half way measures with a gas tank.
Les
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
