Remote starter on a Z with a manual tranny?
Old Jan 27, 2003 | 12:09 PM
AndyB's Avatar
AndyB
Default Remote starter on a Z with a manual tranny?
I have a manual Z on order and I am starting to plan the upgrades. (It's a sickness, I can't help it doc!)
I would like to have a remote starter, but I have never had one on a manual transmission car before. I can easily see how you could bypass the "clutch pressed" safety switch, but is there any way to ensure that the car is not in gear.
I know the car can't shift by itself. What I mean is, can a remote starter be set up to only crank if the transmission is in neutral. I just don't trust myself to NEVER leave it in gear by accident.
Has anyone done this?
Old Jan 27, 2003 | 12:26 PM
Moroccan_Mole's Avatar
Moroccan_Mole
do a search.
there is one guy in houston who has done this... i wouldnt recommend it though, if you leave your car in gear and remote start it ... it could be bad
Old Jan 27, 2003 | 01:52 PM
srobert910's Avatar
srobert910
i used a magnetic reed switch to sense if the shifter is in 1st gear. took me a few hours to make brackets and make sure that it was aligned straight and worked every time. I only park in first or neutral so the other gears weren't a concern.
Old Jan 27, 2003 | 06:09 PM
AndyB's Avatar
AndyB
That's a good point. I could fabricate my own gear shift position sensor.
It is starting to sound like quite a project though. I will need to
Bypass the imobilizer
Bypass the neutral safety
Detect that the car is in neutral
Maybe i will just take my truck when it is really cold. That already has a remote start.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
NiLL
Nov 29, 2021 02:26 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
