Window roll down?
Window roll down?
Was reading in general about this guy's Z being broken into. Something like they jimmy the handles and caused the windows to roll down like one the key fob when you hold unlock down. Now if this is the case, can't we just disable this roll down feature??
I've check the manual and either its can't or i've missed it, but no way to disable the roll down feature.
I've also thought about removing this switch in the handle when I upgrade the front speakers.
Twisty addict
on
If you disable the window roll-down the window will catch on the weatherstripping an start to tear it apart. This option/feature should be left alone.
It's unfortunate what happened to the guy but it doesn't appear to be a common issue unless you're in a high crime area.
04-04-2016 07:52 AM
Boots patrol
Exterior
11-07-2015 12:26 PM
