The rattle in the back is the plastic cover for the brake light on the hatch.
Old Feb 3, 2003 | 09:59 AM
abz123's Avatar
abz123
Default The rattle in the back is the plastic cover for the brake light on the hatch.
Hit it next time you have the hatch opened. It rattles a little when I'm going 90+.
How would you deaden the sound?
Old Feb 3, 2003 | 10:06 AM
chazzg's Avatar
chazzg
Default Re: The rattle in the back is the plastic cover for the brake light on the hatch.
WHY IN THE HELL would you do 90+ with the hatch open????
Old Feb 3, 2003 | 10:09 AM
abz123's Avatar
abz123
Hit the plastic piece not the gas and you will hear the rattle.
Two separate things.
90+ will bring about the rattle when driving it with the hatch close i.e.
Old Feb 3, 2003 | 12:50 PM
westpak's Avatar
westpak
SFZCC
I had the same noise so I took off the cover and light and resinstalled them without any additional material and noise went away!!
Old Feb 3, 2003 | 01:17 PM
slaponte's Avatar
slaponte
Default Is it a rattle, or a squeek?
Because the car just developed a squeek coming from the rear area somewhere recently. So high pitched, I thought it was coming from the speakers at first.
Old Feb 3, 2003 | 01:18 PM
abz123's Avatar
abz123
Cool!
How does it come off? I guess it's in the service manual. The plastic piece feel very lose...just from tapping it lightly.
Old Feb 3, 2003 | 01:20 PM
abz123's Avatar
abz123
It's definately a rattle. Just open up the hatch and tap the plastic lightly and you will hear it.
Old Feb 3, 2003 | 02:37 PM
westpak's Avatar
westpak
SFZCC
Cool!
I can't remember but if you look at it you will see. I believe the cover just snaps on and the light had 2-4 screws. You might want to try just the cover to see.
I curious question are people with this rattle ones that had window tinting done? If that is the case maybe the guys that did it just pulll the cover back and didn't put it back properly?
Old Feb 3, 2003 | 03:46 PM
Lee3Z's Avatar
Lee3Z
I had the same problem. The dealer removed the light and placed styrofoam between the metal frames which corrected the problem.
Old Feb 11, 2003 | 08:04 PM
abz123's Avatar
abz123
Thanks guys....sounds like this problem is pretty common...let me push this back to the top.
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
