350Z leaking oil
Old Feb 7, 2003 | 07:14 PM
zpeedDemon's Avatar
zpeedDemon
Default 350Z leaking oil
Found this from another Forum..
Forum link http://speed.supercars.net/Board?vie...ID=5&tID=46085
http://www.zcar.com/forums/read.php?f=5&i=79144&t=79144
http://www.zcar.com/forums/read.php?f=5&i=79662&t=79662
Old Feb 8, 2003 | 04:43 AM
dougrace zs's Avatar
dougrace zs
Yes my Z does have an oil leak looks like it's comming out of the left exhaust cam cover haven't had a chance to take it to the dealer yet but I will post up what the fix is when I do.
Old Feb 8, 2003 | 06:11 AM
zpeedDemon's Avatar
zpeedDemon
It says that if you start smelling burnt oil, have it checked out at the dealer since youmight be running with insufficient oil.
Old Feb 8, 2003 | 10:01 AM
Intrepid's Avatar
Intrepid
A member of My350Z also reported this issue, but this is the first I'm hearing about it.
https://my350z.com/forum/showthread....light=oil+leak
Old Feb 8, 2003 | 10:31 AM
SandMan's Avatar
SandMan
Default Re: 350Z leaking oil
Don't you love that ford guy on there talking about recalls? LOL.
BTW would an oil leak affect the oil pressure at all? Because my car seems to have pretty good pressure when warming up, but after it reaches operating temp. the oil pressure goes down to 1/4. Is that normal or bad?
Old Feb 8, 2003 | 11:04 AM
Intrepid's Avatar
Intrepid
Normal.
Old Feb 8, 2003 | 03:00 PM
SandMan's Avatar
SandMan
I guess I was just being paranoid. Thanks .
Old Feb 12, 2003 | 04:49 AM
Jumpman--Z's Avatar
Jumpman--Z
How many miles do you have on your car so far?
Old Feb 12, 2003 | 11:55 AM
Z4KR's Avatar
Z4KR
Since I heard about the oil leak issues, I've been keeping an eye on it. Sure enough I've been noticing some oil spots under the car. I have less than 600 miles on the car so far. I mentioned the burning smell to the dealer and they said it was normal. I need to find out where the leak is coming from before taking it back to have it checked.
Old Feb 12, 2003 | 02:51 PM
zpeedDemon's Avatar
zpeedDemon
"To determine if it was oil spilled during the the first change or a leak, he cleaned the engine down, then ran it for awhile. Sure enough, it's a leak. They think it's coming past the intake gasket. They are working on it now to determine the source of the problem"
Old Feb 14, 2003 | 02:05 PM
Z4KR's Avatar
Z4KR
Well, I just crawled under the car and to my surprise.
Old Feb 14, 2003 | 03:30 PM
teh215's Avatar
teh215
That definitely looks like a leak!
Old Feb 14, 2003 | 03:53 PM
Z4KR's Avatar
Z4KR
So that's what they mean by engine (exhaust ) coating
which causes that burning smell
Old Feb 19, 2003 | 01:17 PM
Z4KR's Avatar
Z4KR
I dropped off the car at the dealership this morning for them to check the oil leak and the throw out bearing noise. I was told by the service advisor that it's the extension housing seal that's leaking. The leak is dropping on the exhaust and that's what causing the burning smell and smoke. Anyway, he said that they contacted Nissan and they're waiting for the engineer(s) to show up tomorrow to take a look. He didn't just want to change the seal. Regarding the noise, he told me that it looks like the front input bearing is causing the problem. But, I would say it's not for sure. I took a couple of pictures while he was showing me the leak. I'll post them later tonight. It was a pretty healthy leak. Hope they can find a fix soon. Only have 730 miles on the car.
Old Feb 20, 2003 | 02:41 PM
Z4KR's Avatar
Z4KR
Just got an update from the dealership. Nissan engineers didn't show up yet . I was told that they are researching these issues. Meanwhile, they were told to order a new transmission and drive shaft for my car. Who knows when the parts will be in though. I am gonna go and pick up the car this evening. I guess I can drive it without worrying what happens to the transmission.
Here's a pic of the drive shaft. You can see the leak at the bottom.
Old Feb 22, 2003 | 03:51 PM
stx's Avatar
stx
Angry
Well I too have an oil leak on the left side. I found it while I was changing my oil. Have have 3100 miles on my car. The dealer did my first oil change at 1500 miles. The oil was still gold. When I checked my oil last week with 3000 miles the oil was super dirty like the dealer hadn't changed my oil. So I decided to change it myself only to discover the dealer did change my oil and I developed an oil leak on the left side.
Well hopefully everyone gets their problems fixed.
Old Feb 23, 2003 | 02:56 PM
zwindsor's Avatar
zwindsor
Twisty addict
I also noticed a spot of oil in the belly pan when I first changed the oil at 1200 miles. Got the car back from the dealer Friday after having them do the 3k service and they confirmed that I have an oil leak but they think it's the valve cover gasket. They put dye in the oil and will do a black light test in a couple of days.
Old Feb 24, 2003 | 12:03 PM
stx's Avatar
stx
I noticed that I not only leak it but I am burning it also. When I step on the throttle puffs of blue smoke come out of the exhaust. Anyone else burning oil?
Old Feb 25, 2003 | 09:18 AM
jeffa55's Avatar
jeffa55
Hey Z4KR,
You mentioned a problem with the throw-out bearing. How did this problem manifest itself?? I have a clicking in my tranny...
Old Feb 25, 2003 | 09:54 AM
Z4KR's Avatar
Z4KR
jeffa55,
I just noticed the noise when the car is idling. When I depress the cluch it goes away. It's more obvious when the car is in an inclosed area like the garage. It's not really a clicking sound though. You may have a different problem there. I am now waiting for a new tranny. Good luck.
