Brake bleed order?
Old Feb 8, 2003 | 08:01 AM
bhobson333's Avatar
bhobson333
Question Brake bleed order?
I was looking at the service manual today, getting ready to bleed the brakes. It gives incomplete information!
Bleeding Brake System
CAUTION:
While bleeding, pay attention to master cylinder fluid level.
1. Turn the ignition switch to the OFF position.
2. Connect a vinyl tube to the rear left air bleeder.
3. Fully depress brake pedal 4 to 5 times.
4. With the brake pedal depressed, loosen the air bleeder to let the air out, and then tighten it immediately.
5. Repeat steps 3, 4 until no more air comes out.
6. Tighten the air bleeder to the specified torque.
7. In steps 2 to 6 below, with the master cylinder reservoir tank filled at least half way, bleed air from the front right, rear right, and front left tires, in that order.
Look at step 7! Where does rear left come in? Damn!
Old Feb 8, 2003 | 10:48 AM
mcclaskz's Avatar
mcclaskz
first. check my post on ss lines and bleeding in tech.
Old Feb 8, 2003 | 11:17 AM
bhobson333's Avatar
bhobson333
Thanks. I knew I had seen it somewhere, but I couldn't remember who posted it & I didn't find it on a search.
See you at VIR! (Right?)
Old Feb 8, 2003 | 08:42 PM
grebmohr's Avatar
grebmohr
In addition to the link I will add:
Manuals are not always as clear as they should be.
If you followed every step in that instruction you would have bled 4 calipers in the correct order. It was just written by someone who assumes everyone is thinking exactly the same thing they are.
Heres a thought, What if the instructions confused the line people so much that all of us got Z's without the left rear bled!!??!!
Just a thought.
GL
Also, you can tell how the dual brake safety system is set up by the bleed order.
Old Feb 9, 2003 | 04:36 AM
bhobson333's Avatar
bhobson333
Damn, you're right. I'm the stupid one, not the person who wrote the manual. I didn't read step 2 carefully.
Old Feb 24, 2003 | 05:43 PM
grebmohr's Avatar
grebmohr
Not stupid---
In hundreds of manuals spanning many years and makes. I have seen few worded that poorly.
Hope you problem is fixededed.
Old Feb 25, 2003 | 07:09 AM
John's Avatar
John
In all the cars I've always bled, you always start with the caliper farthest away from the M/C, and then you work your way closer....
