WTF .. ABS Code C1109?
Just changed out my rotors and pads up front, ... and now my car wont rev past 1000 RPM's unless I clear the code..... I see an ABS code of:
C1109
This is really urking the **** out of me... I can drive the car for about 30 seconds .. stop pull over .. clear the code, then restart the car .. drive for 30 seconds... wash rinse repeat. I am beginning to hate my Z.
EDIT: Also.. the ABS BRAKE VDC and SLIP lights are on.
C1109
Originally Posted by DavesZ#3
Did you disconnect or damage one of the wheel speed sensors by chance?
On the way to the dealership, I had to clear it 3 times.. I live about 3 ~ 4 miles from dealer. We hooked up the Consult II to my car and started to drive it around.... and.. NADA.. NOTHING.. ZIP... it would not re-throw the damn code. Drove it for about 15 minutes with moderate to heavy braking. Still nothing. Which worries me even more..
When is this monster going to rear its ugly head again.....
Does anyone know or have a link to all the engine / abs / body Codes?
OK guys... here is the skinny on this code.
IT IS NOT IN THE FACTORY SERVICE MANUAL, Nor in the Consult II DB other than a generic Voltage misread.
This is my *theory* at this time. I recently detailed my engine bay... and I think that somee moisture got into the harness that the runs to the ABS Computer. The Harness is attached to the master brake cyl.
I removed the harness, and cleaned the connectors with some rubbing alc. and.. no code has been thrown since. I think that it was a freak coincidence that this code cropped up right after I changed my rotors/pads.
Hope that if anyone else ever gets this code, they search and find this thread.
