Water leaking from back hatch
Old Jun 6, 2006 | 05:20 AM
sisco534's Avatar
sisco534
Default Water leaking from back hatch
I have water leaking from the back hatch, it seems to be coming from the run off around the back ruber seal.I have noticed a mildew smell and raised the hatch and water is getting in somewhere. Has anyone had this problem? And if so what did you do to fix the problem?
Old Jun 6, 2006 | 06:34 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Have the dealer check the windshield fluid spray lines as they snake through the hinge area. When I was removing my rear wiper arm I discovered the gasket that was suppose to seal the hole was put on poorly leaving a gap where water might run in if I let the car get wet.
Old Jun 6, 2006 | 02:41 PM
showstoppertk's Avatar
showstoppertk
its might also be from your wing. I'd pop off the interior plastic of the hatch to see if you can spot the exact area its coming from. also look for any signs of rust and get that addressed immediately.
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
