AC Fan Stopping on bumps
Old Jun 22, 2006 | 10:57 AM
ZNathanZ's Avatar
ZNathanZ
Default AC Fan Stopping on bumps
Hey guys,
Well today, my AC seems to be stopping when I hit hard bumps in the road...seems to start back a few seconds later...what could be cauing this???
Thanks.
(04 Enthusiast)
Old Jul 3, 2006 | 06:26 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I had a similar problem with my 03. It turns out that I have a short in the ribbon cable behind the 3 climate control *****. Have you installed anything into the dash behind them? The cable was all dinged up and I am in the process of finding another one.
lift up the panel around the shift **** (the one that has the 3 climate control ***** on it) and jiggle the white cable that goes from the 3 ***** to a white/gray box further back. If is goes on and off, that's probably your problem however there are many other potential causes (loose fuse, a short somewhere else etc).
Good luck.
Attached Thumbnails AC Fan Stopping on bumps-img_6024-small-.jpg   AC Fan Stopping on bumps-amplifer.jpg
Old Jul 24, 2006 | 08:08 PM
fonzy's Avatar
fonzy
Good luck.
The same thing is happening to me. I sometimes turn it to the off position and the ac still remains on. Or sometimes it just starts blowing warm air for no reason. Do any of you guys know how much a replacement for this cable would be. I know that it is the cable because i move it around and it starts working normally, but I get tired and frustrated when I have to do this occasionally.
Old Jul 25, 2006 | 06:23 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
You can't just get the cable. You have to get the entire box (at least if you order it from your dealer).
Your best (cheapest) bet is to get it out of a salvaged Z. This is what I did (for $60.00). It is $321.00 new from Nissan.
Old Jul 25, 2006 | 10:32 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Mine just started doing this a week or so ago, I am looking for a way to stiffen the cable a bit so it wont bounce on the bumps. I may also pull the AC box to see if the back plugs are well seated.
Chris
Chris350z03
Oct 8, 2023 07:19 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
mjgfish
Sep 22, 2015 05:55 AM
