Putting my Z on jack stands
Old Jul 29, 2006 | 09:01 AM
deviantZ's Avatar
deviantZ
Question Putting my Z on jack stands
I've done this with other cars with no problems, but I've also never cared about screwing other cars up the way I care about my Z, so could someone with practical experience please tell me how to get my Z on 4 point jack stands?
Note: Tools at my disposal: Floor Jack, OEM jack, 4 jack stands
Normally, I would lift the rear by setting the floor jack under the differential and push up on it, but I'm not sure if that is safe for my car. For the front, I would normally use the crossmember, but I can't really see anywhere that looks suitable to lifting with a floor jack on the Z.
Do I need to do it from one side then the other, and not from front to back? If so, where do I lift from with the jack so as to be able to put my stands in the proper mounting points?
Thanks.
Ryan
Old Jul 29, 2006 | 09:07 AM
plumpzz's Avatar
plumpzz
use the differential and then put the jack stand son the suspension..
Old Jul 29, 2006 | 10:08 AM
deviantZ's Avatar
deviantZ
Thanks, plumpzz, though I have to admit, that sounds a little incomplete. How do I get the fronts in? Where on the suspension do you advise to put the jackstands? Nearly the entire assembly is aluminum, which I wouldn't consider a suitable base for the stands.
Old Jul 29, 2006 | 11:15 AM
plumpzz's Avatar
plumpzz
yeah you're absolutely right about the assembly being aluminum. If im working on the back i tend to do that. If i want the whole car up, i usually do 1 side, then the other. Right in front of the rear tire welll theres a steel frame portion for jacks and lifts, as well as right behind the front tire well. You can put it up from that area on each side.
Old Aug 3, 2006 | 11:32 AM
spacemn_spiff's Avatar
spacemn_spiff
This should help.
Old Aug 3, 2006 | 12:40 PM
mikeg8r's Avatar
mikeg8r
check out
https://my350z.com/forum/2003-2009-nissan-350z/204067-has-anyone-ordered-the-nissan-jack-adapters-for-their-jacks.html
jason@performance's replys, he talks about the proper jack points.
Old Aug 3, 2006 | 12:44 PM
mikeg8r's Avatar
mikeg8r
To jack up the front i need to roll my car up on ramps so I can use my floor jack. I put the jack stands under the side frame of the car where the OEM jack would go (right behind each front wheel, if you look there you will see two notches, that's where you position the stand. It's also in your owners manual)
I put hard rubber bushings on top of the stands so when i lower the car it's not so violent. The bushing are actually suspention spacers that i found at pep boys, they are square about an inch think and fit perfectly ontop of my stands.
Old Aug 3, 2006 | 02:11 PM
VO...'s Avatar
VO...
Administrator
I always use the rear pumpkin to lift the rear. IN the front I place jack stands under the aluminum lower control arms. I haven't had a problem yet.
Old Aug 3, 2006 | 02:17 PM
plumpzz's Avatar
plumpzz
Sorry i shouldve stated. I usually roll on top of my garage which is 2 inches higher than myd riveway.. That allows me to lift the front up.
Old Aug 3, 2006 | 02:33 PM
VO...'s Avatar
VO...
Administrator
That's one low garage roof.
Old Oct 15, 2006 | 07:41 PM
DMK's Avatar
DMK
Going to be doing this soon as well. What the best floor jack I can buy for lowered cars? What brand is generally the best? What's the best min height and max height?
Old Oct 15, 2006 | 08:25 PM
Ztalker's Avatar
Ztalker
best min height is below 3.5", max is above 18". Have some 2x4s handy in the garage to accomodate the floor jack. Bought a nice 3000lb. low profile aluminum jack when it was on sale for 50 bucks from a discount store last summer.
Old Oct 26, 2006 | 04:48 PM
DMK's Avatar
DMK
Anyone know where I could find this locally (Socal)?
http://www.autobarn.net/2-ton-low-rider-floor-jack.html
Is it a good jack or too heavy?
Nm, I figured it's going to be too heavy. Found a Harbor Freight local to me, so I am just going to go there.
Old Oct 28, 2006 | 06:33 PM
DMK's Avatar
DMK
Just bought this one after looking over all the ones at HF.
http://www.harborfreight.com/cpi/cta...emnumber=92782 with free 2 year replacement warranty.
Had a question on jack stands. I was going to get some 2 ton ones, but I noticed that the 4 ton ones said they were for SUV's. I was wondering if the 2 ton jack stands would work on a 4500lb SUV? They should since 4000lb+ of pressure won't be on any one jack stand.
Old Oct 29, 2006 | 12:51 AM
mikeg8r's Avatar
mikeg8r
It depends, I think the SUV ones are taller. Some SUVs may have trouble with a regular jackstand at its maximum height. There might be so much travel in the suspension that the wheels are still on the ground.
Old Feb 14, 2007 | 06:37 PM
cheesewedge's Avatar
cheesewedge
If I wanted to get the entire car up, is this an option? Roll the front up on ramps and jack the rear up with a floor jack to get my stands on both side of the rear. Is this method safe? Looking to doing the exhaust myself and would like to have the entire car up. Thanks
Old Feb 15, 2007 | 09:41 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
If you are not changing cats, you can put the back of the car on ramps and get to everything, no need to lift the front.
Chris
Old Feb 16, 2007 | 03:47 PM
cheesewedge
Thx Chris.... I will be going with HFC so I will need to get the entire car up. I still need to know if it is a good idea to run the front end on ramps and use stands for the rear?
Old Feb 16, 2007 | 09:28 PM
Swiffer's Avatar
Swiffer
I would jack one side up and put the jack stands in place, then go around and do the other side.
When I have to place the car on stands, I place the jack right next to the spots they left open for this purpose and position the jack stands to support to car at those points.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
