Bleeding Brakes
Old Feb 27, 2003 | 11:11 PM
uro279's Avatar
uro279
Default Bleeding Brakes
Hi,
My brakes felt mushy after my last HPDE event. Does it matter if I bleed my brakes immediately after the event? Or can I just do it any time after I feel my brakes brakes mushy? Do the brakes have to be hot or worked hard just prior to bleeding?
I'm asking because I was unable to bleed my brakes after the event and want to do so now.
Any input appreciated.
Thanks!
Old Feb 28, 2003 | 04:48 AM
mcclaskz's Avatar
mcclaskz
Bleed whenever. You would want the brakes cold as not to burn your hands.
Old Feb 28, 2003 | 06:41 AM
uro279's Avatar
uro279
Default Ha!
I love it. Your logic is so pure and clear!
Thanks for the response.
Old Mar 2, 2003 | 09:17 PM
uro279's Avatar
uro279
What about the dual callipers per brembo? Do you have to bleed each one or just the external one? Do I have to remove the wheel or can I bleed with the wheel attached?
Also, where can I place a jack to lift the car (not the Z jack)? Can I lift it via the suspension joint?
Thanks.
lapham3
Oct 7, 2022 03:15 PM
samansharif
Sep 25, 2015 12:31 PM
