Getting 06 Z into driveway.
Old Aug 26, 2006 | 06:55 AM
railrd's Avatar
railrd
Default Getting 06 Z into driveway.
Does anyone know of any type of ramps to use to get over the curb at the end of my driveway? The curbs in my neighborhood are rounded and are the same through out , even at the entery to my driveway. Anyone else with a similar problem. Any help will be greatly appreciated.
Old Aug 26, 2006 | 11:44 AM
r26's Avatar
r26
got pictures? if your car is stock, you shouldn't have any problems. i can make it over a lot of bumps and i am dropped.
Old Aug 26, 2006 | 01:23 PM
kpiskin's Avatar
kpiskin
Did you try to come in at an angle instead of straight in? That usually works for me.
Old Aug 27, 2006 | 10:11 PM
jinsei888's Avatar
jinsei888
enter at an angle, so the wheel meets the curb angle before the front-most edge of your bumper does
Old Aug 28, 2006 | 04:40 PM
rockinbboy's Avatar
rockinbboy
On friday I dropped a friend off and ended up scraping the underside a bit over this bumb which I undercompensated for. On the way back I made sure I entered at an angle. Damn speed bumps! anyways, point being angled entrances are the way to go. Now if your car is modified (ie. lowered + aftermarket bumberlips) then thats another story 'cause even if you entered angled, you may not necessarily be safe.
Old Aug 28, 2006 | 04:45 PM
Photos appreciated.
Old Aug 28, 2006 | 11:28 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I think I know what kind of ramp/curb you're talking about. I vote for making your own ramp or possibly just using sandbags.
You can easily build a ramp using some sheets of plywood, cutting them to various decreasing sizes, stacking them with the largest sheets on the bottom and nailing them together. A project like this should cost no more than $15 at the hardware store.
Old Aug 29, 2006 | 05:08 PM
railrd's Avatar
railrd
Default Found curb ramps
Found curb ramps at J and K Curb ramps. They are made out of recycled rubber.They are 2"x17"x4'. trust me there is no gettin in driveway without them. They're located in western Kentucky, real nice people.
Old Aug 30, 2006 | 08:27 PM
steveiZdaman's Avatar
steveiZdaman
you have a link?
i am currently using wooden planks to get in mine...pain in the butt
Old Aug 31, 2006 | 03:54 PM
railrd's Avatar
railrd
Default Curb Ramps
I first found them at eco-flex.com and they're called e-z drive curb ramps. They are located in Canada and it took them a week just to get back to me with a shiping cost. J and K curb ramps get they're ramps from eco-flex and cost less for shipping. Just go to j and k curb ramps .com . There are pics at both sites.
Old Sep 6, 2006 | 01:38 PM
O3Z's Avatar
O3Z
those ramps are great for anyone lowered with a kit with a steep driveway or garage entrance. great find railrd~!
Old Sep 6, 2006 | 02:49 PM
VO...'s Avatar
VO...
Administrator
+1...I just finished my ramps last night... My V1 lip only has about 3 1/2 clearance.. I used 12 inch wide by 3/4 thick pine wood boards. Stacked them 4 layers high. 1st layer is 31 inches long.. each layer is 5 inches shorter than the previous.. screwed them together with liquid nails inbetween. Works great. No more need for the factory $hitty jack to get the fram high enough for regular floor jack clearance.
Old Sep 6, 2006 | 03:02 PM
mikeg8r's Avatar
mikeg8r
+1 my in-law's neighbor made is own ramp out of some steel plate and bolted it into the ground so it is permanent. I'll take pics next time I am there.
Old Sep 11, 2006 | 09:17 AM
mikeg8r's Avatar
mikeg8r
here are those pics of the ramp
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
KrazY-2K
Apr 24, 2004 04:28 AM
bixby
Jul 11, 2003 02:25 PM
toothlessracer
Dec 18, 2002 04:36 AM
