"Whats that weird creaking noise when i go over bumps?"
Old Sep 18, 2006 | 09:56 PM
Chebosto's Avatar
Chebosto
Default "Whats that weird creaking noise when i go over bumps?"
The Answer:
My friend w/ G35C had this really annoying creaking noise when going over creaks and bumps at low speed. Into Driveways, or over speed bumps, the noise was driving him nuts. sounded almost like a popping noise...
SO. it turned out, his sway bar bushings needed a re-lube.. we had installed hotchkis sways about two years ago, and never checked up on them until this past weekend..
took off the front sway bar, cleaned the bar and cleaned both the bracket and the bushing of past grease and applied new hi temp resistance polyurethane grease. re torqued all the bolts to spec and checked the collars he had installed (still good)
did this for the front and rear bars and now the noise is completely gone.
hope this helps someone-
Cheston
Old Sep 18, 2006 | 10:08 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I may have a little rubbing noise from time to time when going over bumps
And I may also have hotchkis sways
Old Sep 18, 2006 | 10:09 PM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
I have that noise but no sway bars. WTF is it?
Old Sep 18, 2006 | 10:11 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Are you sure about that? I believe the car comes with sway bars.......
Old Sep 18, 2006 | 10:17 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
whats the sound your say? its the cheap **** they used to make our cars and its about to fall apart.
j/k im bored
Old Sep 18, 2006 | 10:27 PM
charlie_rdstr_Z
Woops you're right. I guess the rear sways are giving me a hard time. Good excuse for a Hotckiss upgrade.
Old Sep 18, 2006 | 10:52 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Hmm? Gotta look into that since I recently installed some sways & it does make the same type of noise you described.
Edit: Funny...this happened with my Hotchkis Sways too. Wonder if these sways just need extra lube...
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
