Anyone use Castrol GTX 5w-30?
Old Sep 19, 2006 | 04:43 PM
Mazinger Z's Avatar
Mazinger Z
Default Anyone use Castrol GTX 5w-30?
I got a good deal on 6qts of this stuff, $9.60 plus $3.60 back from a rebate so...it cost me $6 bucks total for 6qts (old guy at Kragen hooked it up), anyways, have you guys used this oil before? Is it good or should I go and exchange it? BTW, this is NON-synthetic...
Old Sep 19, 2006 | 04:58 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It's totally fine. If you don't believe me ask on bobistheoilguy forums... check the packaging and make sure it is API GF-4 / SM rated
http://theoildrop.server101.com/ubb/...=015549#000000
The real question is what will your oil change interval be?
Old Sep 19, 2006 | 05:16 PM
GMZ's Avatar
GMZ
Yep, most dino oils are tons better than people make them out to be. Im using GTX in my truck right now. What kind of driving do you do? Like commute/style wise?
Old Sep 19, 2006 | 05:22 PM
Mazinger Z's Avatar
Mazinger Z
I'm around 6100 miles right now, I don't track the car, but do some spirited driving sometimes. I change my oil every 3k miles so I'm a bit over due as of now. So I'm good to go then? Gonna change it out tomorrow.
Old Sep 19, 2006 | 05:38 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
3k pretty much any oil will do. I would stick to dino oil though.
Unless you seriously abuse your car 3k OCI is overkill, but never hurts to be safe and change more frequently.
Old Sep 20, 2006 | 05:51 AM
VO...'s Avatar
VO...
Administrator
I use the GTX in both my truck/daily driver and my GF's Camery... Oil is oil IMO, unless your comparing conventional with synthetic. That's a different story.
Old Sep 20, 2006 | 07:47 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
vo- the main difference between dino oils is the "additive package" that the company puts in it. They do this to (a) help clean out the engine, (b) provide increased lubricity ... etc.
If you look around "bobistheoilguy" forums, you'll see that there are different schools of thought about which additive packages are the best for different applications.
Also people there have sent in virgin, unused oil for analysis to pinpoint which elements have been added, like molybdenum, phosphorus, etc. This shows you evidence of the additive package.
Old Sep 20, 2006 | 08:11 AM
Biochem7's Avatar
Biochem7
Regular
I use this exclusively in my Z. One of the best dino oils out there.
Old Sep 22, 2006 | 05:09 PM
Spoiled Z's Avatar
Spoiled Z
im using gtx as well i just did my first oil change a month ago and I want to change oil every 3k.
Old Sep 22, 2006 | 09:02 PM
boma's Avatar
boma
Catrol GTX is fine motor oil. Any major brand Penzoil, Mobil, Chevron, Quaker State, Kendall, etc. is fine.
A master mechanic told me once that any motor oil is fine. Even cheap super tech (Wal-Mart) or coastal. It's required that motor oil is made to an industry standard. Motor Oil is Motor Oil.
Get the cheapest major brand oil you can fine and enjoy the savings!
Old Sep 22, 2006 | 10:26 PM
Mazinger Z's Avatar
Mazinger Z
I probably don't have time to change my oil until after I come back from Santa Barbara (Pasadena to Santa Barbara). I"m at 6200 miles right now and I did my last oil change at 3k...is this bad or should I find time to change it before I go?
Old Sep 23, 2006 | 07:48 AM
boma's Avatar
boma
So you put 3,200 on your motor oil so far? You are fine =). You could probably go another 1-2K easy.
Old Sep 23, 2006 | 08:27 PM
Spoiled Z's Avatar
Spoiled Z
I suggest changing it now. I wouldn't want to run over 3k with regular oil.
Old Sep 24, 2006 | 12:46 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Depends on your driving conditions and habits. If you drive it hard all the time, or have harsh conditions (always stop and go, high temp) then 3k is a good OCI.
If your conditions are good, then you can go 5k easily...
Old Sep 24, 2006 | 04:53 PM
Mazinger Z's Avatar
Mazinger Z
I changed the oil about a half hour before my trip up to Santa Barbara. Everything ran pretty good, but I remember after my last oil change, my car felt somewhat faster, but this time...nope, same thing. I guess it's all in my head. Has anyone else felt that way (a faster car) after changing their oil ?
Old Sep 25, 2006 | 01:36 PM
VO...'s Avatar
VO...
Administrator
interesting....
bneumann
Oct 7, 2015 12:16 PM
soshiv
Apr 23, 2007 08:33 AM
crazysets
Nov 12, 2004 04:22 AM
jesfuego
May 24, 2004 10:18 PM
Superfly84zx
Mar 31, 2004 06:37 AM
