window issue
hey whats up everyone. i have had my 04 z for about 3 months. my issue is, when i put my passenger window up, someitimes it has a tendency to go all the way to the top and then comes down a little and stops. so it rises all the way and comes right back down about 5inches. i dont know what it could be. try to help me out guys
take it to the dealership, there always some funky promblems with the windows motor on the Z's. Search a little on the site, you'll see all the different problems people are having.
You need to reset the window motor, it also helps to take the motor apart and clean the contact points. I had the dealer reset it once and the problem came back. I did it myself and cleaned the motor and its been good for a month now. Search for window reset, you should find a thread with pics and detailed instructions on what you need to do.
The window motor needs to be put in time. This is also what they are refering to as reseting. You basically just take the door panel off, find the rubber button in the middle of the panel, its under one of the circular pads that you have to peel back. Connect your switch back up. Press the button, and go manual up to the top, then manual down to the bottom, manual up again to the top, release the button, and then try the auto feature and see if the motor learned the points where it needs to stop or not.
