2004 Nissan 350z "Slip" Light Illumination
Old Sep 22, 2006 | 12:22 PM
gjone300zx's Avatar
gjone300zx
Default 2004 Nissan 350z "Slip" Light Illumination
I very recently purchased a Nissan 350z roadster (Enthusiast) w/30k miles on the odometer. The other day I was driving around 80 on the highway and after abour 30 miles I noticed a shimmy or vibration with a slight deceleration in the vehicle. The "Slip" light also illuminated on the dashboard.
Has anyone had this happen? What does it mean? How do I remedy?
Old Sep 22, 2006 | 12:56 PM
driftk1d's Avatar
driftk1d
this has happened to me b4 too...i have about 13,000 miles on my car but it doesnt do it often. idk why it does that either...any input?
Old Sep 28, 2006 | 07:00 PM
Xx SiFaKa's Avatar
Xx SiFaKa
It has happened too me about 3 times. I just turno off the car and turn it back on, and it's gone.
Old Sep 29, 2006 | 06:38 PM
oman's Avatar
oman
are you guys seriouse? lol u dont know what it is?? hahhahahhh
Old Sep 29, 2006 | 11:46 PM
Xx SiFaKa's Avatar
Xx SiFaKa
If I'm correct I think the guy is asking why his "SLIP" light is staying lit up. I don't think you know that's what this guy is saying. We know when you have the VDC on it lights up the "SLIP" light when you spin the wheels, but sometimes when I spin out the "SLIP" light will stay lit up.
Old Sep 30, 2006 | 09:16 AM
oman's Avatar
oman
Sorry didnt mean to sound like a Jabroni! Yeah that would be a lil wierd for it to stay on? whats the Haps?
Old Sep 30, 2006 | 09:59 AM
Netko350Z's Avatar
Netko350Z
Could be your tires are way out of balance.
Old Oct 3, 2006 | 08:31 AM
Kabs's Avatar
Kabs
its ur clutch. I have the same problem. usually under heavy acceleration and you basically loose power correct? Yea clutch =\ I dont understand how mine is slipping at 24k.
Old Oct 3, 2006 | 08:39 AM
Ray123's Avatar
Ray123
Default clutch
hmmm shouldn't that be under warranty??? i would caln Nissan!
Old Oct 3, 2006 | 01:25 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Do you have aftermarket wheels, or different size tires on the car? Incorrect tire size might cause this problem... ?
Old Aug 6, 2010 | 05:18 PM
superzaza's Avatar
superzaza
Default Slip light indicator
I purchased a used 2006 Nissan 350Z convertible enthusiast. The slip indicator/light would come on without reason. No slipping would occur. The slip indicator would especially come on when talking turns that lead to or exit highways. And when that happens it would cut engine power (limp the car). I doubted many things but luckily I did find the problem at the end. It was that the previous owner had performed a tire rotation, probably not at a Nissan dealer, and they put the rear tires in the front and vice versa. This should not be done to this car as tires sizes are different between front and rear. So I put back the tires in the right places and no more Slip light 
Apparently I learned other reasons for this problem could be Having to top brake fluid, Wheel alignment, Tire size, Speed sensor, Steering angle sensor, Tps or MAF sensors (less likely), Battery change (less likely). Note that I am not an expert, this is the info I got through reading a lot of forums.
Old Aug 6, 2010 | 05:28 PM
DavesZ#3's Avatar
DavesZ#3
Congrats on the new car and having figured out this somewhat common mistake on your own.
Questions about it arose so often it was added to our Top 100 Questions thread...
https://my350z.com/forum/showthread....1&postcount=45
The sad thing is that the previous owner either did this by himself or brought it to a tire shop who should have recognized that the tires were not the same size front/rear.
Old Aug 8, 2010 | 12:49 PM
r00neyo9's Avatar
r00neyo9
I also had a slip light on the car with some slight vibration. In my case i also experienced a feeling in the front right that felt as if my brakes locked. When i got home i jacked up my car took the front right wheel off and saw the little rounded ball in the "stabilizer connecting rod" came loose. # 14 in this pic . I took the whole part off put the ball back into its place and wallah my slip light was gone. Then again it could bee some of the things mentioned up top that cause the slip light to come on.
http://www.*********.com/w/images/3/...ension_001.jpg
Siqcology
Sep 18, 2019 01:45 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
Cam2662
Sep 22, 2015 05:00 AM
hardkicks
Sep 20, 2015 12:28 PM
EnjukuRacing
Sep 11, 2015 08:30 AM
