tran/diff oil ??? Summitracing part#
Can someone make sure these are the correct products. These are saved on my shopping carts.
RED-50204
Gear Lube, MTL Transmission Gear Oil, 75W80, Synthetic, 1 qt., Each
RED-50304
Gear Lube, MT-90 Transmission Gear Oil, 75W90, Synthetic, 1 qt., Each
RED-57904
Gear Lube, Transmission Fluid and Gear Oil, 75W90, Limited Slip,
here is the page.
http://store.summitracing.com/egnsea...s=P%5FRank%7C0
thanks!
RED-50204
RED-50304
RED-57904
here is the page.
thanks!
If you have a Base model Z, do you have the limited slip differential? If not, then why would you get the 75W90 for limited slip?
You need 2 quarts for diff and 4 for trans.
MTL and MT-90 should be fine.
