HELP engine burning oil!!!
Old Oct 9, 2006 | 12:27 PM
pln2311's Avatar
pln2311
Default HELP engine burning oil!!!
I have a 2003 touring model with 13,750 miles on it. The mods are: K&N Typhoon Intake, Kinetix SSV, Alphawerks Headers, Kinetix high-flow cats and Borla true dual exhaust. The last oil change I had the Z was 2 quarts low on oil. I call the dealer and they wanted to do an oil consumption test. I told them I was going to give it 1,000 miles and then try there consumption test. I took it in and it was 1 quart low. They topped it off and I have to bring it back in 700 miles. Could these mods be responsible for that much oil consumption? Has anyone had oil consumption problems w/ or w/o mods? Please help me.
Old Oct 9, 2006 | 01:28 PM
SnakeBitten's Avatar
SnakeBitten
I just came from the dealer just now with the same problem..Since I had my car brand new it was burning oil and has horrible gas milage....I took it to them just 3 1/2 weeks ago when I had the oil changed so they can check the level when I came back today to do the axle tsb....Well its a quart low in less than 200 miles and he just tops it off and tells me to use 10-40 oil from now on...Im like Im not satisfied with that solution....Its a brand new car still under warranty...He says the people inside arent going to put it in for a fix since its not a tsb and they havent heard of any Z's with an oil consumption problem so Im **** out of luck......Im beginning to hate Nissan...Ive gottne the run around with this problem since 3 months of ownership with it ran bone dry........If the 10-40 doesnt work Im trading it in for something else...Not gonna get stuck with a problem car...My car is bonestock by the way. Absolutely nothing added to the engine...No leaks anywhere and no smoke out the exhaust....
Old Oct 9, 2006 | 03:00 PM
pln2311's Avatar
pln2311
Wow thats bullsh*t. I would raise hell. Haven't they heard of the lemmon law? Call this guy at nissan.
Eric Chang
Regional Consumer Affairs Specialist
Nissan North America, Inc.
eric.chang@nissan-usa.com
ph: (310) 771-3853
fax: (310) 771-4486
If he can't help you at least you will feel better by yelling at someone.
Old Oct 9, 2006 | 03:04 PM
zxpwr's Avatar
zxpwr
cool.. thanks for that info ^^
im currently doing the consumption test with the dealer.. if the dealer gives me some bs like "just top it off when low" im calling that number.
Old Oct 9, 2006 | 03:24 PM
CFaddict350z's Avatar
CFaddict350z
Whats the axle tsb?? fixing the clicking?? and lets say i have 54k on my car, is that still covered??
Old Oct 9, 2006 | 03:28 PM
zxpwr's Avatar
zxpwr
http://www.nissanhelp.com/Ownership/.../NTB04-065.htm
NTB04-065
Old Oct 9, 2006 | 03:38 PM
CFaddict350z
Thanks,, is that the instructions for the dealer or what>? i dont plan on doing this myself,, do you know if that would be covered>??
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Fixxxercask
Nov 9, 2015 11:10 AM
