Belt Replacement
Old Oct 14, 2006 | 06:22 AM
danshere's Avatar
danshere
Default Belt Replacement
Anyone have the procedures for replacing the the belts. Are there tensioners or some other way to get the belts loose?
Old Oct 14, 2006 | 08:59 AM
Ztalker's Avatar
Ztalker
there are two tension adjustment pulleys that you need to loosen first before the belts come off. i think you need a 14mm wrench to loosen a bolt in the front and you use a 10 mm to loosen the bottom bolt in order to release the tension of the belt. Search function is your friend, its all there. Good luck.
Old Oct 14, 2006 | 09:22 AM
Eazzy's Avatar
Eazzy
Actually I believe 12 mm on the bottom bolt. 10 mm to get off all the friggin bolts on the plastic cover underneath.
Old Oct 14, 2006 | 09:24 AM
Eazzy's Avatar
Eazzy
Hes off line anyways --Prob under the car cussin out that 10 mm socket that wont go over the head of that bolt. &%*#*&%#*#^*^$ Rant !! *^&%$^&$ !!!!
Rev_Night
Nov 7, 2020 06:00 PM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
