My A/c Doesnt Work!!
Old Oct 30, 2006 | 04:02 PM
breakerboy's Avatar
breakerboy
Default My A/c Doesnt Work!!
What could be going wrong, I have an 03 with about 50 thousand miles on it, and one day a few weeks ago the A/C stopped working. I put it on full blast all the way low temp, and the air coming through is cabin temp...?? Can I fix this any way, and if I take it to the dealer will they do anything about it since the warranty is up already at 50k miles???
thanks
Old Oct 30, 2006 | 04:04 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
did you pop the hood to make sure your belt hasnt busted?
mine went out at like 36k miles. Belt busted, so i replaced it.
Old Oct 30, 2006 | 05:27 PM
Eazzy's Avatar
Eazzy
thanks
At 50,000 ur about due for a A/C Chk. Chances are that ur low or out off freon , which means u have a leak. Leak could be at a fitting or the front seal of ur compressor or even Condenser/Evaporator. First thing to do is plug in Gages and chk Pressure, If ur press. is low ur press. switch wont allow the comp. to engage. Jump the switch to engage it. Pressure ideally will be 250 on the Hi Side and 35 or so on the Low Side. Beyond that --U need to take it in---Not to the dealer ---I really dont think warrenty will cover it, but make sure. A/C is not rocket science but takes experience and unique equipment. All u can do is take it someone u trust cuz A/C guys will ream you. The Dealer will ream u more. My rule of thumb is ---a 50,000 mile A/C redo will run 750-1000.00 if u dont need major component replacement. Minimum is all O-Rings replaced,Drier replaced,Expansion Valve replaced,System flush,Vacuum System, Add Oil, Charge back up. Evaporator replace Labor can be killer.
Old Nov 7, 2006 | 11:20 PM
rbaggett1's Avatar
rbaggett1
I crossed a little over the 50k mark and my A/C just went out today.
Old Nov 8, 2006 | 08:14 AM
VO...'s Avatar
VO...
Administrator
If I'm not mistaken, the compressor works on the same belt as everything else. If the belt snapped, he'd have more problems that just an A/C compressor.
Old Nov 8, 2006 | 08:27 AM
Eazzy's Avatar
Eazzy
Sorry ---U are mistaken
Old Nov 8, 2006 | 08:30 AM
Eazzy's Avatar
Eazzy
Unless Down under and Dirty means Australia----There may be a difference due to difference in design
Old Nov 8, 2006 | 08:46 AM
dkmura's Avatar
dkmura
General & DIY Moderator
There are actually two belts that run off the crank. One runs the PS pump and ancillary systems, while the one to the right runs the A/C.
Looking straight down from the front of the engine, you can see both belts and check if the a/c one has broken. If that's not it, then you probably will need some a/c repairs that others have covered. Just a suggestion, but since your warranty is up, I'd go shop that repair to local and franchise repair dealerships. It's not that difficult a job and you could end up saving some significant money.
Old Nov 8, 2006 | 09:36 AM
VO...'s Avatar
VO...
Administrator
Thank you for the clarification. I've yet to work in the engine compartment yet. Was taking a wild guess.
Old Nov 8, 2006 | 09:37 AM
VO...'s Avatar
VO...
Administrator
not quite, Houton Texas to be exact
Old Nov 8, 2006 | 09:42 AM
Eazzy's Avatar
Eazzy
AHHHH ---I wasnt being a smarta$$---Cars overseas are many times differant due to emissions etc
Old Nov 8, 2006 | 11:26 AM
Ztalker's Avatar
Ztalker
just take it in to get the A/C recharged with dye. The tech can tell if there's a leak in the system. Always run the A/C every now and then year round to keep the o rings lubricated.
Old Nov 8, 2006 | 12:29 PM
VO...'s Avatar
VO...
Administrator
It's all good. I didn't take it in a bad way.
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
