Royal Purple installed in the tranny and differential today.
Old Nov 5, 2006 | 04:36 PM
Nexx's Avatar
Nexx
Default Royal Purple installed in the tranny and differential today.
Stuff is absolutely amazing. Feels like a totally different transmissions. Smoother shifts, less notchiness and its hard to explain but it just grabs each gear better now. I can slap into gear now its so smooth. Only regret is that I didnt do this much much sooner. I would highly recommend this product to everyone.
Old Nov 5, 2006 | 08:55 PM
Kevins350z's Avatar
Kevins350z
can you tell us which RP oil we should buy for the transmittion and rear differential? and where did you get the product from? how much did you paid for the oil?
Old Nov 5, 2006 | 10:31 PM
Nexx's Avatar
Nexx
its the same fluid for the tranny and differential. 75w90 gearmax. i thought mine through amazon.com since i had some gift certificates. you need 6 quarts total.
Old Nov 5, 2006 | 10:46 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
What's the REG cost of this RP?
Old Nov 5, 2006 | 10:54 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
7 a quart
Old Nov 6, 2006 | 06:01 AM
jtabraham's Avatar
jtabraham
How did your old fluid look when you drained it out?
I want to change out my fluid SOOOO bad, but it's 30 to 40 degrees up here in Boston, and my apartment parking lot isn't level enough to safely put the car up on jack stands...i hate paying someone to do a job i can easily do myself!
Old Nov 6, 2006 | 07:58 AM
tcn75's Avatar
tcn75
6 or 7 quarts ? I plan do change it soon. Thanks.
Old Nov 6, 2006 | 08:23 AM
Nexx's Avatar
Nexx
6 quarts, 7 to be safe just incase you spill a bunch of it?
my oil looked ok i guess, but i only had 15k on her.
Old Nov 6, 2006 | 08:34 AM
Eazzy's Avatar
Eazzy
I wanted to go the Redline blend route but its so hard to get my venders to get some in and I dont like ordering online --I just like going down and buying it ---Napa has the RP----Ur pretty happy with it ,Huh ???
BTW ---52,000 miles with no change yet
Old Nov 6, 2006 | 09:33 AM
Mike Wazowski's Avatar
Mike Wazowski
I have been running Royal Purple in my tranny and diff for about 10K miles now and I can only say it gets better and better.
Old Nov 6, 2006 | 10:46 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
seems like most people are happy with synthetics in general...
Old Nov 6, 2006 | 01:03 PM
Nexx's Avatar
Nexx
for the most part. ive read a few people who have changed to redline and felt little or no difference. i have yet to see that from anyone who has tried RP.
Old Nov 6, 2006 | 01:19 PM
Eazzy's Avatar
Eazzy
Iv kept up on all the threads that discussed Lubes and heard so many Pros and Cons. Had read about the possible synchro probs with RP and little difference with Redline etc etc . Had to take so much with a grain of salt. But Im overdue and the RP is available so I quess I'll give it a shot. When it comes to Lubes so much is biased and one mans opinion versus another mans.
AH --- Nexx, You arent a rep with RP are u ??? Hmmm?
Old Nov 6, 2006 | 01:47 PM
Nexx's Avatar
Nexx
rofl nope. i just did a lot of reading before going with RP in my tranny. if i read something was better, then i would have gone with it. i have no love or loyalty to any company. i just buy what i think is best at the time that i can afford.
Old Nov 6, 2006 | 01:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Well I like the redline fluids... I mean while the car's totally cold, it feels like normal OEM fluids, but once the car warms up, there's no comparison... much smoother shifting and I also feel like I can crunch/slam the gears with no ill effects
Old Nov 6, 2006 | 05:56 PM
aren21's Avatar
aren21
Man I need to do this asap, Im tired of waiting and not having time. I took the car to get an oil consumption test started, and also asked about the whine coming from the diff....they said its normal(thats 2 dealers now that say its normal). Im thinking maybe if I change the fluid it might go away. Would it be safe to add in a friction modifier to the diff along with the royal purple to quiet it down a bit??? So is it 2qts diff and 4qts tranny??? Thanks guys.
Old Nov 6, 2006 | 06:05 PM
plumpzz's Avatar
plumpzz
My dealership used RP on the transmission since it is prone to problem (even the new one). It feels great, it feels like it slides into a notch instead of me fighting to push it through.
Old Nov 6, 2006 | 06:08 PM
Mike Wazowski
do not add a friction modifier
Old Nov 6, 2006 | 06:50 PM
aren21's Avatar
aren21
Is there a reason why? How about friction mod. with the oem fluid???
Old Nov 6, 2006 | 06:53 PM
n8vz's Avatar
n8vz
I have Royal Purple MaxGear in my diff for the past 18,000 miles. It works great. No additional friction modifier needed. (RP already added it to MaxGear)
