5th is Grinding (not kewl) on upshift
Abzolutely Zexy
I might need a tranny replaced and was just curious about a few things.
My 2004 (purchased May 2004) just started grinding in 5th (last 4 wks). It has 47k on it and I purchased Royal Purple fluids for the tranny and diff. since it's near 50k miles, I wanted to change the fluids out. I made the appointment with Nissan to change these fluids last Thursday (Nov 16th) and check all my belts, hoses. I told them about the grind and my suspecting the clutch.
After the fluid change the guy took the car out with, me in it, and tried to replicate the grind. It was a positive...he felt & heard the notchy shifting/grinding, and suggested that it was not the clutch, as I suspected, but the transmission. He also stated that I was out of warrenty for the replacement.
I am unable to locate the TSB for this specific grinding and want to know a few things...
1. Owers manual says 60mo/60k on powertrain, this does include clutch/tranny correct?
2. Does changing the fluid to a synthetic GL4 void this warrenty as the service tech informed me?
2) no
If they can tell the difference between a dino and synthetic oil by inspection, then my hats off. Chances are, they'll have no Idea what kind of oil it is. Just don't tell them. Besides, as long as you didn't go with an unapproved viscosity, you don't void your warranty by going synthetic. (Once again, keep your mouth shut on this one. Unless they have engineers on staff, they won't be able to tell what viscosity you're running.)
BUT, if you have any engine mods, you are boned. They will claim the issue is a result of those modifications as they hand you the bill. Well, maybe. some dealerships are better than others. Just be warned.
Most likely, it's your 5th gear syncro going out. The syncros on the nissan transmission are notoriously weak from what I've heard on the forums. Does it pop out of 5th from time to time?
Sorry to hear about this, thats a bummer, man.
I have the same problem but mine is 03 model, over 60k miles does this mean they wont replace the transmission even though it is a TSB problem? Many 03 models have been replaced no questions asked. Should I take it to nissan? Sync is expensive to replace.
all depends on the dealer. some dealers will replace no questions asked some will b!tch and moan, but do it and some will refuse. If one says no, go to another until you find one that will.
Abzolutely Zexy
Originally Posted by USN HM 350Z
Abzolutely Zexy
Originally Posted by 03BrickyardZ
1) yes
2) no
2) no
Thanks for the info. I called my local dealership today and they informed me that they are not setup for this here (no one trained?The town is small...etc.), I had already placed a call to the dealership in Tampa/Brandon, Fla, where I purchased the car, and the service manager stated that this probelm is handled under warrenty, I am covered, the fluids are compatable, and that if they balked bring it to Tampa and they would take care of it!!
So Santa is bringing it for Christmas...I'm getting a new tranny!! YEAH!
Thanks everyone for your help and kindness!
My Z shall be grind free!!
Oh, I'm a ZChick by the way...
I have this problem on a 04.5 roadster at 38k miles. I hope changing the fluids will help.
You should be covered with your mileage or find a mod friendly dealer. At least the tech will admit it cause it's such a PITA getting them to replicate the problem. Hopefully he will tell who ever is servicing it.
Most dealers will just order the replacement transmission - they have no interest (or experience) in rebuild/repair, for warranty replacement they just swap out the entire unit. The economics are in their favor to spend a few hours pulling and replacing the trans vs. many hours even if comp'ed hrs opening it up for any reason.
I saw quite a few cases of this in the 2003 model year, esp. the early Q3/Q4 2002 builds. People who built their engines up early on with stupid power especially found this to be an issue...
Go to the place you bought it, get it resolved ASAP. Fluid is not the answer (other than getting it changed at or before intervals spec'd and using the right grade fluid). Brand is not specified, just GL4.
Abzolutely Zexy
Update:
Had the tranny replaced Dec 27th in Tampa, Florida. They replaced the clutch plate as required and I've had no further problems with my tranny. The clutch got smoother though. I was very surprised at how hard it use to be compared to the lightness of this one!!
JWT clutch is next as Nissan tried to tell me I needed their $1400.00 one that day!
I have no owner manual or anything so i'm going to go out on a limp to ask this. How does the 60k/60months warrenty work? do you have to buy the car from the dealer in order for them to work on it or do you just bring it in regardless of where you got it from? thanks.
Update:
^Is there a TSB number or something? I haven't replicated the problem recently and this will be difficult for them to do so.
search elsewhere, I remember this problem vaguely on this forum in 2002/2003.
hth
Abzolutely Zexy
Originally Posted by hndumafia
how was the service at the brandon nissan dealership? i know they are cool and have the meet at the end of the run, but does their service match up? i have the 5th gear grind (on my second tranny) and am hoping to get it replaced soon. unfortunately, the palm beach dealership that sponsors sfzcc is too far from gville for me to drop it off there.
The number is 813-623-1148 (I-75 to exit . It's only 2 hrs from you and well worth the invested time.
That's cool you got taken care of. My 04.5 base started grinding 5th around 30k... I'm at 35k now.... it doesn't do it all the time and it's really not that bad... but it's still kind of annoying when it happens. I don't know if I should start skipping 5th when I can, or just abuse the hell out of it. A flush obviously did not help it at all. If it gets any worse I'll probably have my tranny replaced before the warranty is up. I'm not real excited about that but what can you do.
